Hi,
I try to install Sonarr on Raspberry Pi and when start this, i get error :
Thanks for help,
Hi,
Thanks for help,
Which version of mono are you running? Sonarr requires 3.10 or later.
Sonarr has already launch and work one time.
After a reboot, impossible to relaunch
mono --version
Mono JIT compiler version 3.10.0 (mono-3.10.0-branch/ce003f4 Tue Nov 25 20:18:29 UTC 2014) Copyright (C) 2002-2014 Novell, Inc, Xamarin Inc and Contributors. www.mono-project.com TLS: __thread SIGSEGV: normal Notifications: epoll Architecture: armel,vfp+hard Disabled: none Misc: softdebug LLVM: supported, not enabled. GC: sgen
If you were running the same version of Sonarr and mono before the reboot then something else changed and negatively affected mono.
This error is happening deep within mono, you may be able to get more information by running mono with the --debug flag, as instructed on the wiki, but it may be worth upgrading mono/re-installing.
Hi,
I have remove and re-installing Mono, now it’s version 4.2 and Sonarr it’s ok !
Thanks for help
