I am running with ubuntu 22.04
Thought I had posted this but I guess I didn’t. I had to re-install sonarr (system blew up). Anyway, I choose to use the option to install sonarr using the snap thing. So, I followed the direction from the Sonarr directions to do this using the command from that. After installation I tried to run sonarr and, apparently nothing was installed. The really strange thing is that I did a search for “sonarr” anyplace in my computer. I found 3 "sonarr"s and here they are (in a file named “System-info.txt”. The problem with that one is that it was a file carried over from 2022 so was not pertinent.
My problem is that I still need to re-install sonarr and want to make sure that I can just do that without fear of screwing something up. When I install again I am going to skip the snap thing and do it the old fashioned way.
I am also trying to install radar and having problems there. radar forum seems really screwed up and it also seems that there is a lot of stuff going on with their installation. Mine messed up and sometimes you both do the same things so, just wondering, what’s going on?
Thoughts?
