Mono version (if Sonarr is not running on Windows): ?
OS: MX Linux
Description of issue: I would like to upgrade Sonarr to v.4. However, I would like to make sure that I don’t run into problems installing the new version and if I do, I would want an easy way to go back to my current version. Your advice therefore is crucial to me and will be much appreciated.
I can make a backup of my current installation of Sonarr from within the program which I installed from the Sonarr website.
The website states that “It’s advisable to make a backup of the v3 data first and uninstall the previous sonarr
package”. However, there’s no information about how to actually uninstall v.3. Can someone please advise how to uninstall Sonarr v.3?
After uninstalling v.3 would restoring the backup that I made with v.3 be fine for v.4?
Would a system backup with Timeshift be effective as a means to restore Sonarr v.3 if things don’t work out with v.4?
