Possible to donwload only brrips/bdrips and exclude blurays?
Hello, is it possible to let Sonarr only download brrips (1080p) and bdrips (1080p) instead of webdl (1080p) or bluray 1080p?
In the profile settings I can’t find the option for brrip’s or bdrip’s and when I manually add them in my folders they get decared as dvd’s.
Any solution?
Thank you very much in advance
How about using tags to restrict or must contain word. Unfortunately the series editor doesn’t have the tags field to change. Maybe you can use the a script using the sonarr API to massively tag all series in one shot.
