**Version 2.0.0.5228
Windows 10:
I was getting a Bad Header Request Error 400 after a new install of Sonarr. I found an article that said to launch with Run As Administrator to resolve this. I did, and it fixed that issue, however I then needed to make a change that required a restart of the service.
When I did, I got the above error PortInUseException. Port 8989 is already in use.
I did a netstat and saw that the port was allocated to Internet explorer. So I killed all instances of IE and tried again, same error.
I edited the config file directly for Sonarr to a different port, ran it again and it came back with the same port exception (on the new port), so it appears to be making it’s own port exception.
Tried re-installing, same issue. When it’s running in Administrator, it can’t see my network drives which hold my data.
Any ideas on how to stop it thinking the port is in use, when it’s launching it itself?
Log details below:
18-8-6 21:52:35.7|Info|Bootstrap|Starting Sonarr - C:\ProgramData\NzbDrone\bin\NzbDrone.exe - Version 2.0.0.5228
18-8-6 21:52:36.6|Info|Router|Application mode: Interactive
18-8-6 21:52:36.9|Info|MigrationLogger|*** Migrating data source=C:\ProgramData\NzbDrone\nzbdrone.db;cache size=-10485760;datetimekind=Utc;journal mode=Wal;pooling=True;version=3 ***
18-8-6 21:52:37.4|Info|MigrationLogger|*** Migrating data source=C:\ProgramData\NzbDrone\logs.db;cache size=-10485760;datetimekind=Utc;journal mode=Wal;pooling=True;version=3 ***
18-8-6 21:52:37.6|Info|OwinHostController|Listening on the following URLs:
18-8-6 21:52:37.6|Info|OwinHostController| http://192.168.1.4:8989/
18-8-6 21:52:37.6|Info|OwinHostController| http://localhost:8989/
18-8-6 21:52:38.0|Info|NancyBootstrapper|Starting Web Server
18-8-6 21:52:40.3|Fatal|WindowsApp|EPIC FAIL
[v2.0.0.5228] NzbDrone.Host.Owin.PortInUseException: Port 8989 is already in use, please ensure NzbDrone is not already running. —> System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. —> System.Net.HttpListenerException: Access is denied
at System.Net.HttpListener.AddAllPrefixes()
at System.Net.HttpListener.Start()
at Microsoft.Owin.Host.HttpListener.OwinHttpListener.Start(HttpListener listener, Func2 appFunc, IList
1 addresses, IDictionary2 capabilities, Func
2 loggerFactory)
at Microsoft.Owin.Host.HttpListener.OwinServerFactory.Create(Func2 app, IDictionary
2 properties)
at System.RuntimeMethodHandle.InvokeMethod(Object target, Object[] arguments, Signature sig, Boolean constructor)
at System.Reflection.RuntimeMethodInfo.UnsafeInvokeInternal(Object obj, Object[] parameters, Object[] arguments)
at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture)
at Microsoft.Owin.Hosting.ServerFactory.ServerFactoryAdapter.Create(IAppBuilder builder)
at Microsoft.Owin.Hosting.Engine.HostingEngine.StartServer(StartContext context)
at Microsoft.Owin.Hosting.Engine.HostingEngine.Start(StartContext context)
at NzbDrone.Host.Owin.OwinAppFactory.CreateApp(List1 urls) in C:\BuildAgent\work\5d7581516c0ee5b3\src\NzbDrone.Host\Owin\OwinServiceProvider.cs:line 52 --- End of inner exception stack trace --- at NzbDrone.Host.Owin.OwinAppFactory.CreateApp(List
1 urls) in C:\BuildAgent\work\5d7581516c0ee5b3\src\NzbDrone.Host\Owin\OwinServiceProvider.cs:line 63
at NzbDrone.Host.Owin.OwinHostController.StartServer() in C:\BuildAgent\work\5d7581516c0ee5b3\src\NzbDrone.Host\Owin\OwinHostController.cs:line 53
at NzbDrone.Host.NzbDroneServiceFactory.Start() in C:\BuildAgent\work\5d7581516c0ee5b3\src\NzbDrone.Host\ApplicationServer.cs:line 61
at NzbDrone.Host.Router.Route(ApplicationModes applicationModes) in C:\BuildAgent\work\5d7581516c0ee5b3\src\NzbDrone.Host\Router.cs:line 47
at NzbDrone.Host.Bootstrap.Start(ApplicationModes applicationModes, StartupContext startupContext) in C:\BuildAgent\work\5d7581516c0ee5b3\src\NzbDrone.Host\Bootstrap.cs:line 78
at NzbDrone.Host.Bootstrap.Start(StartupContext startupContext, IUserAlert userAlert, Action`1 startCallback) in C:\BuildAgent\work\5d7581516c0ee5b3\src\NzbDrone.Host\Bootstrap.cs:line 41
at NzbDrone.WindowsApp.Main(String[] args) in C:\BuildAgent\work\5d7581516c0ee5b3\src\NzbDrone\WindowsApp.cs:line 23
