I have sonarr up and running on my htpc. I have it set to download through rtorrent on my whatbox seedbox into a specified folder (seedbox/sonarr files) that im sync’d to with BTSync so it downloads them locally (E:/Sonarr). All that works great… But the problem im having is, once i have i have the files in the local folder, i cannot figure out a way to get sonarr to scan that folder and sort to my shared library. Would this be possible using the drone factory options (i have no idea what drone factory options really are)?? Any help would be greatly appreciated…
Don’t use Drone Factory.
Use a remote path mapping in Sonarr to tell Sonarr where to look.
Host: Same as host field from download client settings
Remote Path: Path the download client reports
Local Path: Local path where Sonarr can find the files.
So if I set it up that way sonarr with automatically download the episode from my seedbox to my local drive and sort it where it needs to go??
Not sure its working.
Under host I have beans.whatbox.ca
Remote file location is /home/user/files/Sonarr files/ this is the directory Sonarr puts downloads.
And local is E:\TV Shows
Is this how I should have it??
If the local path is mounted via SSHFS or similar then it will.
This needs to be a path mounted to the seedbox, not where Sonarr is going to sort the files.
