Please help No files found are eligible for import
Mono version (if Sonarr is not running on Windows):5.20.1.34
OS: Synology DSM 6.2.2-24922 Update 4
Debug logs: https://docs.google.com/document/d/190HbkfNbgs-HrqrZlqFvc5N8a0alerJBb_zBs21dLtw/edit?usp=sharing
Import failed, path does not exist or is not accessible by Sonarr: /volume1/Downloads/30.Rock.S01E01.1080p.BluRay.x264.1-BEDLAM-Obfuscated/
yes. that’s why I’m here. I don’t know why and/or how to correct it.
I’m guessing permissions if everything (sonarr and download client) is running as a native package on the syno.
Do both run as the same user, or do they belong to the same group? Does that user or group have access to the path?
Check the entire path starting from volume1 and see if sonarr can access it.
You can do a quick test from the gui, go to manual import and try to browse to the path. It won’t tell you why, but you will see at which level in the directory structure it’s failing.
