Sonarr version (exact version): 3.0.2.560 Mono version (if Sonarr is not running on Windows): OS: Windows 10 pro Debug logs: https://pastebin.com/ZKYb3Ett Description of issue:
Hi
Pastebin link above. Here’s the problem that I tried to capture in the debug log.
Search for Detroit Metal City
No automatic results, no interactive results, same on single episodes.
But if I go to dognzb or nzbgeek, it is there, easily searchable.
Both indexers are tested in sonar, green checkmarks.
On Dognzb they’re in the anime category using absolute episode numbers, but your logs show Sonarr searching for it as a standard episode, fix the series type in Sonarr and make sure you’ve set the anime categories properly for each indexer.
Ah, pilot error once again! May I ask, I recently read some debate on the necessity of category numbers at all now, and also using say, 5300 vs just using 5000. Could you comment on that?
