I created a python script that checks trakt and netflix recently added, and based on filters you set, adds the show to sonarr for you. So you no longer have to check for new shows you want to add.
I made it for myself but figured i’d release and get suggestions on it!
I tried to use it but unfortunately it doesn’t work for me.
I’ve defined IT as my country but the script can’t find any results using justwatch.
Allflicks doesn’t exist anymore unfortunately so I can’t use it.
Can you please support me?
I’ve maybe found that the api call should be it_IT against en_IT but if I manually change this values in justwatch.py nothing changes (I’m not a programmer…).
