Mono version (if Sonarr is not running on Windows): 6.12.0.182
OS: unRAID
Debug logs: Hastebin: Send and Save Text or Code Snippets for Free | Toptal®
Description of issue: I upgraded to unRAID v6.11.5 and now I get an error when Sonarr is trying to process a release. It downloads to the array, but when it’s trying to change the file name and move it from the temp folder to the final destination, it can’t.
I’ve run the unRAID “Docker Safe New Perms” that says:
" You should use this tool in case a misconfigured docker application (notably CouchPotato or Sonarr / SickBeard) has written media files to your array with the wrong permissions, and you find yourself unable to modify / delete those files."
Couldn’t import episode /tv/letterkenny.s11e01.2160p.web.h265-ggez/5fc2100932694416895968f97df06acf.mkv: Access to the path ‘/tv/letterkenny.s11e01.2160p.web.h265-ggez/5fc2100932694416895968f97df06acf.mkv’ is denied.
