Mono version (if Sonarr is not running on Windows):3.10.0 (tarball Sat Mar 28 10:11:51 UTC 2015)
OS: Synology
Debug logs (posted to hastebin or similar):
Hi I had to rebuild my NAS drive, everything was going ok up until today but im having issues with Sonarr renaming / moving files. I never had to mess with permissions on the previous setup.
I have checked both the source and destination folder and both are set to read / write. Any advice would be great.
ImportApprovedEpisodes|Couldn’t import episode
System.UnauthorizedAccessException: Access to the path is denied.
at System.IO.File.Move (System.String sourceFileName, System.String destFileName) [0x0013a] in /spksrc/native/mono/work-native/mono-3.10.0/mcs/class/corlib/System.IO/File.cs:319
at NzbDrone.Common.Disk.DiskProviderBase.MoveFile (System.String source, System.String destination, Boolean overwrite) [0x000d0] in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Common\Disk\DiskProviderBase.cs:210
at NzbDrone.Common.Disk.DiskTransferService.TryMoveFileTransactional (System.String sourcePath, System.String targetPath, Int64 originalSize, DiskTransferVerificationMode verificationMode) [0x0008e] in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Common\Disk\DiskTransferService.cs:384
at NzbDrone.Common.Disk.DiskTransferService.TransferFile (System.String sourcePath, System.String targetPath, TransferMode mode, Boolean overwrite, DiskTransferVerificationMode verificationMode) [0x003e2] in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Common\Disk\DiskTransferService.cs:206
at NzbDrone.Common.Disk.DiskTransferService.TransferFile (System.String sourcePath, System.String targetPath, TransferMode mode, Boolean overwrite, Boolean verified) [0x0000e] in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Common\Disk\DiskTransferService.cs:90
at NzbDrone.Core.MediaFiles.EpisodeFileMovingService.TransferFile (NzbDrone.Core.MediaFiles.EpisodeFile episodeFile, NzbDrone.Core.Tv.Series series, System.Collections.Generic.List1 episodes, System.String destinationFilePath, TransferMode mode) [0x0010e] in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\MediaFiles\EpisodeFileMovingService.cs:118 at NzbDrone.Core.MediaFiles.EpisodeFileMovingService.MoveEpisodeFile (NzbDrone.Core.MediaFiles.EpisodeFile episodeFile, NzbDrone.Core.Parser.Model.LocalEpisode localEpisode) [0x0005e] in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\MediaFiles\EpisodeFileMovingService.cs:80 at NzbDrone.Core.MediaFiles.UpgradeMediaFileService.UpgradeEpisodeFile (NzbDrone.Core.MediaFiles.EpisodeFile episodeFile, NzbDrone.Core.Parser.Model.LocalEpisode localEpisode, Boolean copyOnly) [0x00119] in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\MediaFiles\UpgradeMediaFileService.cs:64 at NzbDrone.Core.MediaFiles.EpisodeImport.ImportApprovedEpisodes.Import (System.Collections.Generic.List1 decisions, Boolean newDownload, NzbDrone.Core.Download.DownloadClientItem downloadClientItem) [0x0024e] in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\MediaFiles\EpisodeImport\ImportApprovedEpisodes.cs:90
