“Perfection” of a tv series = having every episode, in the maximum quality specified for that series.
For example, if I specify Game of Thrones (3 seasons x 10 episodes each, that’s 30 episodes and say I have 25 episodes on disk) -AND- if my quality setting is HD-All (every one of the 10 quality settings from SD-TV to BlurRay-1080p), then “100% perfection” means I have all 25 episodes on disk at BluRay-1080p quality. If a few are lower quality, then the 100% goes down to a lower number.
Logic:
Assign a weighting value to each quality in the series’ quality profile, for example:
1=SDTV
2=DVD
3=WEBDL-720p
4=Bluray-720p
5=WEBDL-1080p
6=Bluray-1080p … so “6” equals the “perfect” quality in this example. -
Calculate perfection rating:
( (# of episodes at quality1)*1 + (# of episodes at quality2)*2 + … + (# of episodes at quality6)*6 ) / (total # of episodes on disk * 6) * 100 -
Either display the number (it is a percentage so 100% = perfection) or some sort of graphical represention, next to each series on the home page and at the top of each series page, so you know at a glance how close to “perfection” you are, ie you know if you still need to find some better quality episodes to achieve the quality level you’ve specified.
