I didn’t see this on trello or on here:
Would it be possible to add a setting for a season to be set to a different location? For example, season 1 is watched/all downloaded but I want to move it to another location (archival) but keep season 2 on in the original spot.
IE:
\server1\folderXYZ\showname\season 02\ (currently watching/downloading/etc)
\server2\folderXYZ\showname\season 01\ (downloaded but still monitored, etc)
LJ
We have no plans to support multiple series folder locations at this time.
ok. I’ll figure out a way to do it on the windows side then with folder substitutions maybe. Basically, I was wanting to increase space onto another NAS without having to tweak my settings/folders.
Thanks Markus!
LJ
If you don’t mind swapping your server OS to linux, symlinks are easy.
Not too difficult on Windows either. Even some explorer extensions.
Indeed. I was tempted to make my new server Linux… probably will.
Windows I was thinking MKLINK to create links as needed; or, like markus said, get some 3rd-party software to do it!
LJ
