2.0.0.5228
4.2.3
OS
mint 18 :
I had my system mounting tv1 tv2 tv3 into tv and movie1 movie 2 into movie
i then had a folder called mediashare and had tv and movie mounted in it
but i changed the drives by moving all the shows into folders called tv and movie on each drive
then just mounted the drives in mediashare so it ended up looking the same
mediashare/tv
radarr and sickrage had no problem with this. but sonar would not see the path any longer
the original worknig path would be like /mediashare/tv/startrek
but after i changed the drives sonarr now need a traling slash
so all my path need to be changed to /mediashare/tv/startrek/
I wish i knew sql so i could add that slash. i tried to manualy edit the database and changed about 1/8 of the shows.
