Open Sonarr to Calendar Rather Than Series
Sonarr Version 4.0.8.18740-Jul 16 2024.
It has been a couple years since I have used Sonarr, is there a way to change what screen is displayed when you first open Sonarr?
For example have Sonarr open the calendar screen instead of the series screen?
Much Appreciated,
Johnny
Don’t know if this will help but I have 3 tabs set to launch when my browser is opened. Group Speed Dial, Sonarr calendar, and Google. In my case I click use current pages to have them as startup.
You can create a bookmark to any page and use that to open Sonarr to that page, you cannot change the default page displayed any other way.
Not accurate as I stated I have my startup pages for Vivaldi as Group Speed Dial, Sonarr’s calendar, and Google. You just can’t change it within Sonarr.
Startup page is essentially a bookmark that opens automatically.
So, it’s the same thing… You can use a bookmark, but you can’t change the default.
