Only Manual Importing
Hey Markus,
Let me start by saying I’m a real goose, so I’ve probably not set it up correctly. I’m using the latest version of sonarr and I’ve pasted in the logs below.
None of my downloads are automatically importing into my plex folder. Instead the just sit in the activity section until I manually import them.
I’m using deluge and SAB as download clients. I have completed download handling enabled but I have drone factory disabled and set to another, unrelated, folder after seeing that advice in another thread but that still hasn’t fixed.
The error that shows says “indeterminate download path” but I haven’t seen any other threads describing this error.
Hopefully you can tell me how to fix this?
16-2-6 10:33:11.4|Info|NzbSearchService|Searching 7 indexers for [The Eric Andre Show : S03E10]
16-2-6 10:33:23.3|Info|DownloadDecisionMaker|Processing 29 releases
16-2-6 10:33:48.2|Info|Sabnzbd|Adding report [The.Eric.Andre.Show.S03E10.Bird.Up.PROPER.720p.WEBRip.AAC2.0.h264-monkee-Obfuscated] to the queue.
16-2-6 10:33:48.8|Info|DownloadService|Report sent to SABnzbd. The.Eric.Andre.Show.S03E10.Bird.Up.PROPER.720p.WEBRip.AAC2.0.h264-monkee-Obfuscated
16-2-6 10:34:39.0|Info|SeriesService|Adding Series [253463][Black Mirror] Path: [E:\Downloads\Television\Black Mirror]
16-2-6 10:34:39.0|Info|SceneMappingService|Updating Scene mappings
16-2-6 10:34:39.1|Warn|MediaCoverMapper|File C:\ProgramData\NzbDrone\MediaCover\41\poster.jpg not found
I hope that’s the right logs, this is the only mention of this episode which is the last one I had this issue with.
Tried re downloading and the full error text says: The.Eric.Andre.Show.S03E10.Bird.Up.PROPER.720p.WEBRip.AAC2.0.h264-monkee-Obfuscated
Intermediate Download path inside drone factory, Skipping.
I have now figured this out. I forgot to click “save” when changing the drone factory folder.
Sorry to waste your time, but I did admit I’m a real goose up front!
you have the drone factory folder inside your download path. put it somewhere else, so that it is not the download path. including a higher and lower folder.
