as request from the nzbToMedia issue tracker,
i’ve added a link to the log file
tell me if it’s the right one
https://db.tt/R7E3TcCq
Can you enable trace level for 2 minutes. I would like to know what the uTorrent api returns. (If the POI episode is still listed in uTorrent.)
But before posting check the content, I’m not sure if uTorrent tracelogs is properly sanitized yet.
it’s isn’t anymore in the list,
do you want me to re-download another episode just for testing ?
I would appreciate that.
i tried to check for passkeys/apikeys etc but i’m not 100% if i was able to remove them all.
but i sended you a PM with 2 links to the logs
I’ve changed some code on the develop branch to fix the double extension. Will make it’s way into the torrent branch eventually.
thnx,
only issue what still is here would be that the file is being removed so i’m not able to seed it anymore.
a little bump,
didn’t give it a new try yet.
but is there already a fix so the file isn’t beeing moved so i can keep seeding ?
i know i can enable “Use Hardlinks instead of Copy” but that also means the files downloaded from usenet will be copied and not moved.
or is this the only way ?
“Use hardlinks instead of Copy” only affects torrents.
Hey Trash, I know you use nzbToMedia too like me, everything seems to work okay with CDH turned off for me. I also have “use hard links instead of copy” turned on and that seems to work well too. The only problem I get occasionally is when a episode is replaced by a repack or higher quality release and the episode is seeding at the time, in that case the old episode won’t be replaced by the new. Also, I am not using the drone factory folder. Let me know if you are having any specific issues as maybe I can help since we are in the same boat.
i also got CDH turned off,
and togethr with nzbToMedia that works
but we where testing the option with CDH turned on.
it almost worked only issue was that nzbDrone moved the file,
but i will turn on “Use hardlinks instead of Copy” to see if that does work together with CDH.
i only download the quality i want so didn’t test the option what happens when you replace a file.
The one problem I was having when I had CDH turned on with nzbToMedia was that all the torrent downloads were getting processed twice, once by nzbdrone and once by nzbToMedia. Has that been fixed or is that still happening?
I also noticed that issue,
going to give that a try.
i got a day free today so i can keep a eye on it what happens
little update.
turned on CDH
enabled "Use hardlinks instead of Copy"
when the file is downloaded and nzbToMedia processes the file but doesn’t rename the file (remove tracker name).
it seems that it works without a issue.
but i still think it’s beeing processed 2 times by nzbDrone.
when nzbToMedia renames the file (removes tracker name)
then it results in a error.
first the file that nzbToMedia sends to Drone get’s processed,
then Drone processes the file again but the one that was downloaded with tracker name.
and then i’m not able to seed the file anymore because it’s gone.
beeing that i use the Recycling Bin option in Drone i can see that Drone moved the renamed file of nzbToMedia.
