HI,
My version of Drone is the latest (NzbDrone Ver. 2.0.0.1861), and Mono version 3.10, running on Ubuntu.
My issue is that NZBDrone will find an episode from an indexer, and will send the request to SAB, no problem. SAB will then download it without issue, and will unpack and move it to the Completed folder.
However, the second that NZBDrone sends it to SAB, the little downloading icon appears, but no purple progress bar appears in SAB. If I F5 while in Drone, then the ! icon appears, and it says no episode on disk.
In logs I get no clues, I’ve tried on a couple of different shows, it just seems to send the report to SAB and then completely forget about it. Any ideas?
14-9-11 22:10:52.4|Info|NzbSearchService|Searching 2 indexers for [Series Name : S01E10]
14-9-11 22:10:54.4|Info|FetchFeedService|Finished searching Nzb.su for [Series Name : S01E10]. Found 3
14-9-11 22:10:56.3|Info|FetchFeedService|Finished searching OZnzb.com for [Series Name : S01E10]. Found 6
14-9-11 22:10:56.3|Info|DownloadDecisionMaker|Processing 9 reports
14-9-11 22:11:03.3|Info|Sabnzbd|Adding report [SeriesName.S01E10.720p.BluRay.x264-NODLABS] to the queue.
14-9-11 22:11:06.4|Info|DownloadService|Report sent to download client. SeriesName.S01E10.720p.BluRay.x264-NODLABS
14-9-11 22:16:43.4|Info|NzbSearchService|Searching 2 indexers for [Series2 : S08E02]
14-9-11 22:16:45.2|Info|FetchFeedService|Finished searching Nzb.su for [Series2 : S08E02]. Found 0
14-9-11 22:16:46.5|Info|FetchFeedService|Finished searching OZnzb.com for [Series2 : S08E02]. Found 0
14-9-11 22:16:46.5|Info|DownloadDecisionMaker|No reports found
14-9-11 22:16:52.6|Info|NzbSearchService|Searching 2 indexers for [Series2 : S06E12]
14-9-11 22:16:54.3|Info|FetchFeedService|Finished searching Nzb.su for [Series2 : S06E12]. Found 1
14-9-11 22:16:54.8|Info|FetchFeedService|Finished searching OZnzb.com for [Series2 : S06E12]. Found 1
14-9-11 22:16:54.8|Info|DownloadDecisionMaker|Processing 2 reports
14-9-11 22:17:01.0|Info|Sabnzbd|Adding report [Series2.S06E12.PDTV.x264-FTP] to the queue.
14-9-11 22:17:02.3|Info|DownloadService|Report sent to download client. Series2.S06E12.PDTV.x264-FTP
