Sonarr version (exact version): 2.0.0.4472 Mono version (if Sonarr is not running on Windows): 4.2.1 (Debian 4.2.1.102+dfsg2-7ubuntu4) OS: Ubuntu 16.04 ((Debug logs)): https://hastebin.com/qefolutagi.tex Description of issue: When I try to manually add an episode to the download queue I get the message, “Error Response Received from SABnzbd:”
Not sure if this is relevant to my issue but I just switched from SB and I had everything working fine for a bit until my hard drive filled up with backlog downloads. After clearing up space and emptying the queue it seems Sonarr and SAB are no longer working well together: Under Activity->Queue I see a lot of Downloaded messages followed by “No files found are eligible for import in [filepath]”.
SAB’s logs indicated that the NZB was empty. It turned out that I bumped up against my OZnzb download limit because when I set up Sonarr for the first time, it went looking for a bunch of missing episodes. All is working fine now. Loving my switch to Sonarr so far… a modern SB.
