Not snatching Torrents automatically
Hello all,
I have Sonarr set up and running and everything is working perfectly with one slight issue…I have to manually search for torrents. When I do a manual search the torrents appear, and I can download them successfully, rename, etc, but when I hover over the red exclamation point (basically, showing why that file wasn’t “chosen” by Sonarr), I see this:
“Torrent is not enabled for this series”
Can you tell me why that is? I’ve checked every possible setting I can think of in Sonarr and uTorrent.
Thanks,
MJ
Check your delay profiles, either the default one or one linked to that series is set to Usenet Only.
@markus101,
I’m not sure I understand that answer. As far as I can tell, in Sonarr version 2.0.0.3243, only one delay can be set. And I do not see a setting anywhere for “Usenet Only”. If I’m missing something, please educate me. Below are what I believe are the most relevant settings for this issue…let me know if something is set incorrectly and I can supply additional setting information, logs, etc. if needed. I have also pasted the settings for a show that shows the flag “Torrent is not enabled for this series” when doing a manual search (ALL my series show this flag).
FYI, Sonarr + Usenet works perfectly. Also, when I manually search for something Sonarr will show the torrents, and if I select one Sonarr will push it to uTorrent. However, once the file is downloaded Sonarr won’t import it automatically (even though it is in the folder it is expecting). I have to manually import.
So I really have 2 issues I’m trying to solve (they could be related).
  1. Sonarr is not using torrents to automatically download contant.
  2. Sonarr will not automatically import files from torrent after manually search/select/download. (the fix for 1 could fix 2).
Settings for a Show with Flag “Torrent is not enabled for this series”
Monitored = Yes
Use Season Folder = Yes
Profile = HD-All
Series Type = Standard
Path = (XXXXXX)
Tags = (blank)
Sonarr Settings
Media Management
	Episode Naming
		Rename Episodes = Yes
		Include Series Title = Yes
		Include Episode Title = Yes
		Include Quality = No
		Replace Spaces = No
		Separator = Dash
		Numbering Style = S01E05
		Season Folder Format = {Series Title} - {season:00}
	File Management
		Ignore Deleted Episodes = No
		Recycling Bin = (blank)
Profiles
	Any
		English
		SDTV
		DVD
		WEBDL-480p
		Bluray-720p
		HDTV-720p
		WEBDL-720p
		Bluray-1080p
		HDTV-1080p
		WEBDL-1080p
	SD
		English
		SDTV
		DVD
		WEBDL-480p
	HD-720p
		English
		Bluray-720p
		HDTV-720p
		WEBDL-720p
	HD-1080p
		English
		Bluray-1080p
		HDTV-1080p
		WEBDL-1080p
	HD-All
		English
		Bluray-720p
		HDTV-720p
		WEBDL-720p
		Bluray-1080p
		HDTV-1080p
		WEBDL-1080p
	DVD
		English
		SDTV
		DVD
		WEBDL-480p
Quality
Indexers
	Name = KickassTorrents
	Enable RSS Sync = Yes
	Enable Search = Yes
	Website URL = http://kat.cr
	Verified Only = Yes
	Name = Nyaa
	Enable Search = Yes
	Website URL = http://www.nyaa.se
	Name = OZNZB
	Enable Search = Yes
	Website URL = https://api.oznzb.com/
	API Key = (XXXXXXX)
	Name = Usenet-Crawler
	Enable Search = Yes
	Website URL = https://www.usenet-crawler.com
	API Key = (XXXXXXX)
	Minimum Age = 45
	Retention = 0
Download Clients
	Name = SABNZBD
	Enable = Yes
	Host = localhost
	Port = 8080
	API Key = (XXXXXXXX)
	Username = (XXXXXXX)
	Password = (XXXXXXX)
	Category = tv
	Recent Priority = High
	Older Priority = Normal
	Use SSL = Yes
	Name = uTorrent
	Enable = Yes
	Host = localhost
	Port = 7070
	Category = tv-sonarr
	Recent Priority = First
	Older Priority = First
	Completed Download Handling
		Enable = Yes
		Remove = Yes
	Failed Download Handling
		Redownload = Yes
		Remove = Yes
General
	Start-Up
		Port Number = 8989
		URL Base  = (blank)
		Open browser on start = Yes
	Security
		Authentication = Basic (Browser Popup)
		Username = (XXXXXXXXX)
		Password = (XXXXXXXXX)
		API Key  = (XXXXXXXXX)
Logging
	Log Level = Info
Analytics
	Enable = Yes
—End Settings----
@markus101,
Scratch that Markus. I found the issue. It was between the chair and the keyboard…me. Sorry to bug you guys.
Thanks,
Matt
