Not pulling from torrentleech
I have iptorrents setup working no problem. I disabled ipt to get other indexers working as well.
I have torrentleech as indexer. The url and api is no problem.
When running rss sync i see the following.
RSS Sync Completed. Reports found: 100, Reports grabbed: 0
I can manually go to the RSS feed and I see the show I want is there. I have any and all selected as options. Any ideas?
J
Debug logs will show you why it was rejected, could be a number of reasons.
15-3-20 13:05:00.8|Debug|DownloadDecisionMaker|Release rejected for the following reasons: [Permanent] Unknown Series
15-3-20 13:05:00.8|Debug|Parser|Parsing string 'Jimmy Kimmel 2015 03 19 Bill Murray-The Cast of The Walking Dead 720p HDTV x264-CROOKS’
15-3-20 13:05:00.8|Debug|Parser|Episode Parsed. jimmykimmel - [Unknown Episode]
15-3-20 13:05:00.8|Debug|Parser|Language parsed: English
15-3-20 13:05:00.8|Debug|NzbDrone.Core.Parser.QualityParser|Trying to parse quality for Jimmy Kimmel 2015 03 19 Bill Murray-The Cast of The Walking Dead 720p HDTV x264-CROOKS
15-3-20 13:05:00.8|Debug|Parser|Quality parsed: HDTV-720p v1
15-3-20 13:05:00.8|Debug|Parser|Release Group parsed: CROOKS
15-3-20 13:05:00.9|Debug|ParsingService|No matching series jimmykimmel
15-3-20 13:05:00.9|Debug|DownloadDecisionMaker|Release rejected for the following reasons: [Permanent] Unknown Series
15-3-20 13:05:00.9|Debug|Parser|Parsing string 'Jimmy Kimmel 2015 03 19 Bill Murray-The Cast of The Walking Dead HDTV x264-CROOKS’
15-3-20 13:05:00.9|Debug|Parser|Episode Parsed. jimmykimmel - [Unknown Episode]
15-3-20 13:05:00.9|Debug|Parser|Language parsed: English
15-3-20 13:05:00.9|Debug|NzbDrone.Core.Parser.QualityParser|Trying to parse quality for Jimmy Kimmel 2015 03 19 Bill Murray-The Cast of The Walking Dead HDTV x264-CROOKS
15-3-20 13:05:00.9|Debug|Parser|Quality parsed: SDTV v1
15-3-20 13:05:00.9|Debug|Parser|Release Group parsed: CROOKS
Unknown series…
So is it because the series is The Tonight Show with Jimmy Kimmel and the release is just Jimmy Kimmel? Is there a way to match it?
I believe Doctors is a UK daily show. That show I only added as a way to test.
I have also been trying with bitmetv. Again, only IPT seems to work out of IPT, bitmetv, and torrentleech.
http://pastebin.com/i60r7qsk when using bitmetv.
It should have pulled Arrow, The Goldbergs, The Middle, and The Mysteries of Laura. Any ideas?
I really enjoy Sonarr and glad to see it develop the way it has.
Is Doctors a daily show as well? Could you pastebin some more debug logs, nothing obvious in these logs points to an issue.
Unknown series is either an alternate name required or incorrect parsing, but there is already an alias for Jimmy Kimmel.
Sorry I edited instead of replied.
Here is my reply.
nzbdrone12 - Pastebin.com when using bitmetv.
Hello,
I didn’t want to make a new post so I’m posting here. I am having the same issue. On my logs, it would say 100 reports found and 0 grabbed for Torrentleech as my only indexer.
I am very new to this and just started setting it up. I am planning on only grabbing from Torrentleech. I believe I setup the index correct. With the URL as default url (http://rss.torrentleech.org) and the API is the code after the URL I got from TL (http://rss.torrentleech.org/APICODEHERE).
I went to the actual RSS and looked at the content listed. I added the series on Sonarr and made it choose any quality. Almost all my settings are default as far as restrictions on the index and quality. I have the same setup for kickass.to as my indexer and everything works perfectly. I am wondering if this is an issue from Torrentleech?
Here is my debug log: [http://pastebin.com/jjpFjgDX][1]
Thanks!
[1]: http://pastebin.com/jjpFjgDX
