Sonarr version (exact version): 3.0.3.896
OS: Windows Server 2012 r2
Results when searching for S07E04
https://pastebin.com/46y7TT22
Description of issue: Not detecting the correct episodes, I believe this might be an XEM issue.
So far I’ve only noticed this with Paw Patrol Season 7, it also only seems to be an issue when trying to download those episodes, if I manually grab them and let sonarr rename the files then everything seems fine, but if I manually search I don’t get the correct results and if I manually download but add the sonarr label so it detects the episode, it will detect the wrong episode numbers during the download process and incorrectly rename it.
For example, when downloading
S07E01E02 is being mistaken as S07 E01, E02, E03 and E04.
S07E03 is being mistaken for E05 and E06.
When I manually search for episodes I get the following results.
Episodes 3 and 4 will only show E01E02,
Episodes 5 and 6 will show episodes from seasons 1,2,3 and S07E03.
Episode 7 shows episodes for season 1,2,3,4 and S07E04E05
Episodes 8 and 9 shows episodes for season 1,2,3 and 4
Episode 10 will only show S07E06E07
