**Sonarr version 2.0.0.4949 **:
**Mono version 4.6.2 **:
OS Synology:
**((Debug logs)) https://hastebin.com/raw/zukupugoki *:
Sonar was working perfectly until a couple of weeks ago, the main problem is that it’s not grabbing the episodes automatically. Every time I have to manually click on search for episodes and then it finds them directly:
Are the series and episodes monitored?
Are you using manual search to find them?
Do you have ((debug logs)) of an RSS Sync when an expected release wasn’t grabbed? (Not sure what the logs you linked contained, but we’ll need to know what in that file we’re looking for, a release name ideally).
@markus101
The series and episodes are monitored.
No the standard is automatic search, but because it’s not finding the episodes I use manual search afterwards.
I will post a debug log tomorrow morning after the RSS Sync
@markus101 Sorry for the delay, but there are no episodes to grab for 2 days. I will post a debug log tomorrow
@markus101 Turns out, my indexers weren’t working, added some new ones and everything is up and running smoothly.
A different question, I want to use a payed indexer. Which one would you recommend?
Any of the presets in Sonarr are good, I have no recommendation beyond that.
