Not finding nzbplanet or nzbgeek
Trying to set up my indexers and not able to install nzbplanet or nzbgeek.
OS:
based on all the information you’ve provided (none at all)
You’re setting them up wrong.
i downloaded sonarr for windows and when i open indexers there is no + to add other indexers?
And what do you see if you go to Sonarr -> Settings -> Indexers
There used to be a plus sign and nothing now. Just names of other indexers
Screenshot?
It’s 100% there… maybe you need to scroll down?
There is a Plus and when i click on it i get (fanzub) (newznab) . Should I click on any of them and fill in with info from nzb planet
No fanzub is not newzab nor geek nor planet
Planet and geek are both presets under newznab
Do you have windows sonarr
perhaps you should try netflix? It doesn’t require this complicated computer stuff like thinking at what’s on the screen and following exactly what you were told to :smiley:
FWIW Sonarr is the same UI across OS
Thank You very much for your help
