Not finding indexer results from Jackett
Running version 3.0.4.1059 on Windows 10.
Sonarr is not showing any results even though they show in Jackett, for certain shows. The main indexers I am using are all public: 1337x, ETTV, EZTV, TPB
Here are some examples:
Have you set the show to daily? (It uses dates for releases, that’s necessary)
What do the debug logs show?
Yes, show is set to daily.
Here are the log entries I can find:
21-1-7 11:21:29.6|Info|NzbSearchService|Searching 5 indexers for [Jeopardy! : 2021-01-04]
21-1-7 11:21:29.7|Trace|HttpClient|Req: [GET] https://torrentapi.org/pubapi_v2.php?get_token=get_token&app_id=Sonarr
21-1-7 11:21:29.7|Trace|ConfigService|Using default config value for 'proxyenabled' defaultValue:'False'
21-1-7 11:21:29.9|Trace|HttpClient|Res: [GET] https://torrentapi.org/pubapi_v2.php?get_token=get_token&app_id=Sonarr: 200.OK (272 ms)
21-1-7 11:21:30.0|Debug|Rarbg|Downloading Feed https://torrentapi.org/pubapi_v2.php?mode=search&search_tvdb=77075&search_string=%222021%2001%2004%22&ranked=0&category=18%3B41%3B49&limit=100&token=(removed)&format=json_extended&app_id=Sonarr
21-1-7 11:21:30.0|Trace|RateLimitService|Rate Limit triggered, delaying 'torrentapi.org' for 2.695 sec
21-1-7 11:21:32.7|Trace|HttpClient|Req: [GET] https://torrentapi.org/pubapi_v2.php?mode=search&search_tvdb=77075&search_string=%222021%2001%2004%22&ranked=0&category=18%3B41%3B49&limit=100&token=(removed)&format=json_extended&app_id=Sonarr
21-1-7 11:21:32.7|Trace|ConfigService|Using default config value for 'proxyenabled' defaultValue:'False'
21-1-7 11:21:33.0|Trace|HttpClient|Res: [GET] https://torrentapi.org/pubapi_v2.php?mode=search&search_tvdb=77075&search_string=%222021%2001%2004%22&ranked=0&category=18%3B41%3B49&limit=100&token=(removed)&format=json_extended&app_id=Sonarr: 200.OK (281 ms)
21-1-7 11:21:33.0|Debug|NzbSearchService|Total of 0 reports were found for [Jeopardy! : 2021-01-04] from 5 indexers
21-1-7 11:21:33.0|Debug|NzbSearchService|Setting last search time to: 2021-01-07 4:21:33 PM
21-1-7 11:21:33.0|Info|DownloadDecisionMaker|No results found
21-1-7 11:21:39.7|Info|NzbSearchService|Searching 5 indexers for [Days of our Lives : S56E73]
21-1-7 11:21:39.8|Debug|Rarbg|Downloading Feed https://torrentapi.org/pubapi_v2.php?mode=search&search_tvdb=70366&search_string=S56E73&ranked=0&category=18%3B41%3B49&limit=100&token=(removed)&format=json_extended&app_id=Sonarr
21-1-7 11:21:39.8|Debug|Torznab|Downloading Feed http://localhost:9191/api/v2.0/indexers/1337x/results/torznab/api?t=tvsearch&cat=5000,5030,5040,5070,5080,8000,8010,100005,100006,100007,100009,100040,100041,100071,100074,100075&extended=1&apikey=(removed)&offset=0&limit=100&q=Days%20of%20our%20Lives&season=56&ep=73
21-1-7 11:21:39.8|Trace|HttpClient|Req: [GET] http://localhost:9191/api/v2.0/indexers/1337x/results/torznab/api?t=tvsearch&cat=5000,5030,5040,5070,5080,8000,8010,100005,100006,100007,100009,100040,100041,100071,100074,100075&extended=1&apikey=(removed)&offset=0&limit=100&q=Days%20of%20our%20Lives&season=56&ep=73
21-1-7 11:21:39.8|Trace|ConfigService|Using default config value for 'proxyenabled' defaultValue:'False'
21-1-7 11:21:39.8|Trace|HttpClient|Req: [GET] https://torrentapi.org/pubapi_v2.php?mode=search&search_tvdb=70366&search_string=S56E73&ranked=0&category=18%3B41%3B49&limit=100&token=(removed)&format=json_extended&app_id=Sonarr
21-1-7 11:21:39.8|Debug|Torznab|Downloading Feed http://localhost:9191/api/v2.0/indexers/ettv/results/torznab/api?t=tvsearch&cat=5000,5030,5040,5045,5060,5070,5080,100005,100007,100041,100072,100077,100089&extended=1&apikey=(removed)&offset=0&limit=100&q=Days%20of%20our%20Lives&season=56&ep=73
21-1-7 11:21:39.8|Debug|Torznab|Downloading Feed http://localhost:9191/api/v2.0/indexers/thepiratebay/results/torznab/api?t=tvsearch&cat=5000,5040,5050,100205,100208&extended=1&apikey=(removed)&offset=0&limit=100&q=Days%20of%20our%20Lives&season=56&ep=73
21-1-7 11:21:39.8|Debug|Torznab|Downloading Feed http://127.0.0.1:9191/api/v2.0/indexers/eztv/results/torznab/api?t=tvsearch&cat=5000&extended=1&apikey=(removed)&offset=0&limit=100&q=Days%20of%20our%20Lives&season=56&ep=73
21-1-7 11:21:39.8|Trace|RateLimitService|Rate Limit triggered, delaying 'localhost' for 1.967 sec
21-1-7 11:21:39.8|Trace|RateLimitService|Rate Limit triggered, delaying 'localhost' for 3.961 sec
21-1-7 11:21:39.8|Trace|HttpClient|Req: [GET] http://127.0.0.1:9191/api/v2.0/indexers/eztv/results/torznab/api?t=tvsearch&cat=5000&extended=1&apikey=(removed)&offset=0&limit=100&q=Days%20of%20our%20Lives&season=56&ep=73
21-1-7 11:21:39.9|Trace|ConfigService|Using default config value for 'proxyenabled' defaultValue:'False'
21-1-7 11:21:40.0|Trace|HttpClient|Res: [GET] https://torrentapi.org/pubapi_v2.php?mode=search&search_tvdb=70366&search_string=S56E73&ranked=0&category=18%3B41%3B49&limit=100&token=(removed)&format=json_extended&app_id=Sonarr: 200.OK (230 ms)
21-1-7 11:21:40.5|Trace|HttpClient|Res: [GET] http://127.0.0.1:9191/api/v2.0/indexers/eztv/results/torznab/api?t=tvsearch&cat=5000&extended=1&apikey=(removed)&offset=0&limit=100&q=Days%20of%20our%20Lives&season=56&ep=73: 200.OK (629 ms)
21-1-7 11:21:41.8|Trace|HttpClient|Req: [GET] http://localhost:9191/api/v2.0/indexers/ettv/results/torznab/api?t=tvsearch&cat=5000,5030,5040,5045,5060,5070,5080,100005,100007,100041,100072,100077,100089&extended=1&apikey=(removed)&offset=0&limit=100&q=Days%20of%20our%20Lives&season=56&ep=73
21-1-7 11:21:41.8|Trace|ConfigService|Using default config value for 'proxyenabled' defaultValue:'False'
21-1-7 11:21:43.2|Trace|HttpClient|Res: [GET] http://localhost:9191/api/v2.0/indexers/1337x/results/torznab/api?t=tvsearch&cat=5000,5030,5040,5070,5080,8000,8010,100005,100006,100007,100009,100040,100041,100071,100074,100075&extended=1&apikey=(removed)&offset=0&limit=100&q=Days%20of%20our%20Lives&season=56&ep=73: 200.OK (3411 ms)
21-1-7 11:21:43.8|Trace|HttpClient|Req: [GET] http://localhost:9191/api/v2.0/indexers/thepiratebay/results/torznab/api?t=tvsearch&cat=5000,5040,5050,100205,100208&extended=1&apikey=(removed)&offset=0&limit=100&q=Days%20of%20our%20Lives&season=56&ep=73
21-1-7 11:21:43.8|Trace|ConfigService|Using default config value for 'proxyenabled' defaultValue:'False'
21-1-7 11:21:44.2|Trace|HttpClient|Res: [GET] http://localhost:9191/api/v2.0/indexers/ettv/results/torznab/api?t=tvsearch&cat=5000,5030,5040,5045,5060,5070,5080,100005,100007,100041,100072,100077,100089&extended=1&apikey=(removed)&offset=0&limit=100&q=Days%20of%20our%20Lives&season=56&ep=73: 200.OK (2362 ms)
21-1-7 11:21:45.0|Trace|HttpClient|Res: [GET] http://localhost:9191/api/v2.0/indexers/thepiratebay/results/torznab/api?t=tvsearch&cat=5000,5040,5050,100205,100208&extended=1&apikey=(removed)&offset=0&limit=100&q=Days%20of%20our%20Lives&season=56&ep=73: 200.OK (1192 ms)
21-1-7 11:21:45.0|Debug|NzbSearchService|Total of 0 reports were found for [Days of our Lives : S56E73] from 5 indexers
21-1-7 11:21:45.0|Debug|NzbSearchService|Setting last search time to: 2021-01-07 4:21:45 PM
21-1-7 11:21:45.1|Info|DownloadDecisionMaker|No results found
Please upload the complete log file somewhere and link it here, selective snippets aren’t helpful.
The only thing I can tell for certain is:
Jackett wasn’t queried for the jeopardy episode, only rarbg was.
Days of our Lives searched Jackett via different URLs a bunch of times and got 0 results, the query looks fine so either the categories are wrong or there is an issue with how Jackett made the request to the indexer.
Along those lines, I have 3 indexers 2 NZB and a RSS from a torrent site. Sonarr flat out REFUSES to use the RSS, even when you disable the other 2 indexers. It will tell you that there are no matches. I have taken to having to manually download some episodes and then have Sonarr import them!!!
Then open your own thread with all the requested information, hijacking another thread isn’t going to help.
Wow, was not trying to hijack! My issue seemed the same. Will NEVER make the mistake again!
Sorry. Does this work for the log files? Weird that Jackett indexers are not being queried for Jeopardy. Not sure what is happening with Days of our Lives either. Could it be something to do with the S__E__ format vs S__E0__?
https://drive.google.com/file/d/1no6J9oKJw09WdnJUG-gUFmml5dP8fTQd/view?usp=sharing
https://drive.google.com/file/d/1m-uYkNr_CI06ByNmOaStM5ZgYUZ7zPuv/view?usp=sharing
appears to just not be on torrent indexers; is on usenet tho
also the series type should be set to daily
There seems to be separate issues here.
From the logs, Sonarr doesn’t appear to be querying Jackett indexers for Jeopardy, but Jackett itself does show results. I do have Jeopardy set to daily.
For Days of our Lives, Jackett shows results, the logs show Sonarr is sending queries, but still results are not being shown in Sonarr.
Bug, twas fixed
v3.0.4.1061
Yup, updating to the latest version fixed the bug with Jeopardy. Nice!
The Days of our Lives issue I am not sure about still because I can use the same search terms from the api in the Sonarr logs that I use in Jackett, but I still get no results.
Yet none of these yield results:
http://localhost:9191/api/v2.0/indexers/zooqle/results/torznab/api?t=tvsearch&cat=5000,5070,103583&extended=1&apikey=(removed)&offset=0&limit=100&q=Days%20of%20our%20Lives&season=56&ep=77
http://localhost:9191/api/v2.0/indexers/thepiratebay/results/torznab/api?t=tvsearch&cat=5000,5040,5050,100205,100208&extended=1&apikey=(removed)&offset=0&limit=100&q=Days%20of%20our%20Lives&season=56&ep=77
http://localhost:9191/api/v2.0/indexers/kickasstorrents-to/results/torznab/api?t=tvsearch&cat=5000,5070,5080,103583&extended=1&apikey=(removed)&offset=0&limit=100&q=Days%20of%20our%20Lives&season=56&ep=77
http://localhost:9191/api/v2.0/indexers/ettv/results/torznab/api?t=tvsearch&cat=5000,5030,5040,5045,5060,5070,5080,100005,100007,100041,100072,100077,100089&extended=1&apikey=(removed)&offset=0&limit=100&q=Days%20of%20our%20Lives&season=56&ep=77
http://localhost:9191/api/v2.0/indexers/1337x/results/torznab/api?t=tvsearch&cat=5000,5030,5040,5070,5080,8000,8010,100005,100006,100007,100009,100040,100041,100071,100074,100075&extended=1&apikey=(removed)&offset=0&limit=100&q=Days%20of%20our%20Lives&season=56&ep=77
http://localhost:9191/api/v2.0/indexers/eztv/results/torznab/api?t=tvsearch&cat=5000&extended=1&apikey=(removed)&offset=0&limit=100&q=Days%20of%20our%20Lives&season=56&ep=77
I’m guessing it has something to do with the S__E__ format vs S__E0__ maybe?
from the urls it looks like you do, but could you confirm you have that series set to standard, not daily? i mean it is a daily but if theyre uploading it as s00/e000 and not a date then you need to make sure its set that way in sonarr.
they also all have 5000 in them so it should match the TV category.
you could potentially try manually searching in jackett with the date instead and if that has results then maybe try changing the series to daily and then searching through sonarr to see if that works?
also, just to make sure its exactly the same search, you may want to set the indexer and groups in jackett when searching, just in case. also turn off dead torrents (unless sonarr includes them in its search).
some of the manual search results for that series look horrible - its like could you please pick a format
a lot of it is going to come down to the indexer being able to find the correct season/episode from the meta data (or manual tagging) on their end.
check those urls, sonarr isnt actually asking for s56e77 (or e077, like you are in jackett) its asking for season 56, episode 77, meaning the indexer has to know (or jackett has to mangle it when passing it on to the indexer) for it to return the right results.
Hmmm, ya I’m not sure if there is a solution.
I tried setting the show to daily and it still didn’t have any results. Turned off dead torrents in Jackett, searched each individual indexer. The formats are definitely all over the place like you said, but for whatever reason Sonarr is not able to find the proper results.
I’ll keep grabbing this show manually for now I suppose.
Appreciate the help in trying to look into things.
v2 is EOL; V3 is now stable
upgrade this is more than likely resolved
