Version 2.0.0.5344
Mono Version 5.18.0.240
pi@pi-tor2:~ $ cat /etc/os-release
PRETTY_NAME=“Raspbian GNU/Linux 10 (buster)”
NAME=“Raspbian GNU/Linux”
VERSION_ID=“10”
OS: Pi4
Sonnar is mostly working fine for me, the issue I’m having on when it gets animi I keep ending up with chinease subtititles instead of english. I’m not sure how to control for that…? Idealy I would like to control for the sub group as well (like only get subplease releases… Not sure how to do that either?
I have typicaly public indexers Toykyo tosh ect. I also have jacket setup to proxy.
It’s working for english shows fine but for anime I keep having to go find and redown load with english subs, kind of defeating the purpose :).
Help?
I’m looking over the links but I’m not sure I get it: Could I trouble you for example of how I might enforce getting english subs, or enforce using getting the releases done [SubsPlease] for example? I’m not quite seeing how to put it togather… Thanks!
Okay I maybe sort of figured it out? There perhaps there is a better way way.
went to setting release profiles, made to item name subrules
added prefered /(HorribleSubs|SubsPlease|SallySubs)/i score 250
(note I think horriblesubs is gone but whaterver).
I made a tag engsubs
I set this to use tokoyo tosh
I went to anime and added the tag
trigged a DL
It seemed to be correctly grabbing a subplease release from the right tracker.
