Sonarr version (exact version): 2.0.0.3934
Mono version (if Sonarr is not running on Windows): Mono JIT compiler version 4.2.1
OS: Ubuntu 14.04
Debug logs (posted to hastebin or similar): http://termbin.com/3292
Since updating to 3934, all my quality/profiles have dissapeared. Seems to fail around here:
Marr.Data.DataMappingException: The DataMapper was unable to load the following field: 'Items' value
and then
Parameter name: id ---> System.ArgumentException: ID does not match a known quality
Parameter name: id
at NzbDrone.Core.Qualities.Quality.FindById (Int32 id) [0x0004b] in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Qualities\Quality.cs:122
at NzbDrone.Core.Qualities.Quality.op_Explicit (Int32 id) [0x00000] in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Qualities\Quality.cs:127
at NzbDrone.Core.Datastore.Converters.QualityIntConverter.ReadJson (Newtonsoft.Json.JsonReader reader, System.Type objectType, System.Object existingValue, Newtonsoft.Json.JsonSerializer serializer) [0x00007] in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Datastore\Converters\QualityIntConverter.cs:57
at Newtonsoft.Json.Serialization.JsonSerializerInternalReader.DeserializeConvertable (Newtonsoft.Json.JsonConverter converter, Newtonsoft.Json.JsonReader reader, System.Type objectType, System.Object existingValue) <0x404fc080 + 0x001b1> in <filename unknown>:0
at Newtonsoft.Json.Serialization.JsonSerializerInternalReader.SetPropertyValue (Newtonsoft.Json.Serialization.JsonProperty property, Newtonsoft.Json.JsonConverter propertyConverter, Newtonsoft.Json.Serialization.JsonContainerContract containerContract, Newtonsoft.Json.Serialization.JsonProperty containerProperty, Newtonsoft.Json.JsonReader reader, System.Object target) <0x404dd6d0 + 0x00137> in <filename unknown>:0
at Newtonsoft.Json.Serialization.JsonSerializerInternalReader.PopulateObject (System.Object newObject, Newtonsoft.Json.JsonReader reader, Newtonsoft.Json.Serialization.JsonObjectContract contract, Newtonsoft.Json.Serialization.JsonProperty member, System.String id) <0x404da920 + 0x0089f> in <filename unknown>:0
at Marr.Data.Mapping.MappingHelper.LoadExistingEntity (Marr.Data.Mapping.ColumnMapCollection mappings, System.Data.Common.DbDataReader reader, System.Object ent, Boolean useAltName) [0x000b1] in m:\BuildAgent\work\6c3239faf2b92630\src\Marr.Data\Mapping\MappingHelper.cs:79
at Marr.Data.Mapping.MappingHelper.CreateAndLoadEntity (System.Type entityType, Marr.Data.Mapping.ColumnMapCollection mappings, System.Data.Common.DbDataReader reader, Boolean useAltName) [0x00012] in m:\BuildAgent\work\6c3239faf2b92630\src\Marr.Data\Mapping\MappingHelper.cs:40
at Marr.Data.Mapping.MappingHelper.CreateAndLoadEntity[T] (Marr.Data.Mapping.ColumnMapCollection mappings, System.Data.Common.DbDataReader reader, Boolean useAltName) [0x00000] in m:\BuildAgent\work\6c3239faf2b92630\src\Marr.Data\Mapping\MappingHelper.cs:25
at Marr.Data.DataMapper.Query[T] (System.String sql, ICollection`1 entityList, Boolean useAltName) [0x0008d] in m:\BuildAgent\work\6c3239faf2b92630\src\Marr.Data\DataMapper.cs:577
at Marr.Data.QGen.QueryBuilder`1[T].ToList () [0x00052] in m:\BuildAgent\work\6c3239faf2b92630\src\Marr.Data\QGen\QueryBuilder.cs:279
at Marr.Data.QGen.SortBuilder`1[T].ToList () [0x00000] in m:\BuildAgent\work\6c3239faf2b92630\src\Marr.Data\QGen\SortBuilder.cs:176
at Marr.Data.QGen.SortBuilder`1[T].GetEnumerator () [0x00000] in m:\BuildAgent\work\6c3239faf2b92630\src\Marr.Data\QGen\SortBuilder.cs:247
at System.Linq.Enumerable.SingleOrDefault[TSource] (IEnumerable`1 source) <0x40497e20 + 0x000cb> in <filename unknown>:0
at NzbDrone.Core.Datastore.Extensions.RelationshipExtensions+<>c__DisplayClass2`2[TParent,TChild].<HasOne>b__1 (IDataMapper db, TParent parent) [0x0001f] in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Datastore\Extensions\RelationshipExtensions.cs:21
at Marr.Data.LazyLoaded`2[TParent,TChild].LazyLoad () [0x0002f] in m:\BuildAgent\work\6c3239faf2b92630\src\Marr.Data\LazyLoaded.cs:108
at Marr.Data.LazyLoaded`1[TChild].get_Value () [0x00000] in m:\BuildAgent\work\6c3239faf2b92630\src\Marr.Data\LazyLoaded.cs:34
at NzbDrone.Core.DecisionEngine.Specifications.QualityAllowedByProfileSpecification.IsSatisfiedBy (NzbDrone.Core.Parser.Model.RemoteEpisode subject, NzbDrone.Core.IndexerSearch.Definitions.SearchCriteriaBase searchCriteria) [0x0002d] in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\DecisionEngine\Specifications\QualityAllowedByProfileSpecification.cs:21
at NzbDrone.Core.DecisionEngine.DownloadDecisionMaker.EvaluateSpec (IDecisionEngineSpecification spec, NzbDrone.Core.Parser.Model.RemoteEpisode remoteEpisode, NzbDrone.Core.IndexerSearch.Definitions.SearchCriteriaBase searchCriteriaBase) [0x00000] in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\DecisionEngine\DownloadDecisionMaker.cs:132
Any ideas?
Sidenote, I’m not sure how I got on to version 3934 since the latest (according to sonarr itself) is 3913, possible I’m on a diff version from the apt repository?
Thanks!
