Hello, I just installed Sonarr, trying to install NZBPlanet as an indexer, but cannot save and add.
I checked with NZBPlanet, and my setting are correct… so I’m not sure what I need to adjust.
I have setup NZBGet successfully.
I’m hoping someone has a thought or two that may help.
( I’m new to the news NZB world… been on torrents for a long time )
Thx, Thrasher
Did you add your API key ? (found on NZBPlanet)
- add your API key
- press test and see if you get any errors, if you don’t get errors goto tep 3
- press save and you’re done.
if you get a error we need to know what the error is.
Hello TRaSH, thank you…
Sorry, I should have been more descriptive… my bad.
So I setup my account with NZBPlanet, got my key, and put it into the indexers section under, preset Newsnab API Key… step 1 that you show.
Then I ran the test, and got an error, and was unable to save and add.
“Unable to connect to indexer, check the log for more details"
I went to the log,
” Newznab Unable to connect to indexer: Unable to connect to the remote server "
“NzbDroneErrorPipeline Invalid request Validation failed:
– Unable to connect to indexer, check the log for more details”
I’ve been able to setup uTorrent, and NZBGet with no issues.
I also went to the NZBPlanet help desk, and they said my setup looks good. ( I sent screenshots to them )
They even asked me to try removing API. from the URL… which I did, and didn’t help.
I appreciate any suggestions…
thanks
Thrasher…
We’ll need more information:
OS:
((Debug logs)):
_(Make sure debug logging is enabled in settings and post the
The log files are especially important, so we know exactly what failed and why.
Hello
I’m running on Win7
Here is the log error…
Message
System.Net.WebException: Unable to connect to the remote server —> System.Net.Sockets.SocketException: No connection could be made because the target machine actively refused it 127.0.0.1:62523
at System.Net.ServicePoint.ConnectSocketInternal(Boolean connectFailure, Socket s4, Socket s6, Socket& socket, IPAddress& address, ConnectSocketState state, IAsyncResult asyncResult, Exception& exception)
Thanks
Thrasher
Also, BTW, I just changed my modem… I thought that may be part of the issue… but it didn’t help. Same error.
I am using a gig modem
thanks
Thrasher
If the indexer isn’t running on the same system as Sonarr, I’d say bad proxy settings or some sort of malware.
Thank you Markus101
You Rock !!!
Malware…
and now I’m rocking with Sonarr…
Thank you very much for your advise…
Thrasher
