Hey Guys,
Im a long time Sonarr user and first time NGINX user.
I am using Cent OS 7 and running NGINX as a system service using systemctl. I am running Sonarr as a docker.
I am confused about what and where my config file should be and go for NGINX.
I have the file located at "/etc/nginx/sites-enabled/d2.mydomain.com
Config:
server {
listen 80;
server_name d2.mydomain.com;
location / {
proxy_pass http://127.17.0.4:8989;
proxy_set_header X-Real-IP $remote_addr;
proxy_set_header Host $host;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
proxy_set_header X-Forwarded-Proto $scheme;
proxy_redirect off;
access_log /var/log/nginx/d2.prometheus.ooo;
The IP “http://127.17.0.4:8989” is my docker container IP.
I have added the base URL /sonarr in the sonarr docker but I get the error “The page you are looking for is not found.” when i navigate to “d2.mydomain.com/sonarr”
Any help would be great
