Next Airing should put "Ended" shows in a separate visual block
It’s odd that The Diplomat in my Next Airing list is after Coupling. Coupling ended like 12 years ago (at least) and The Diplomat is coming back in a year or so.
I’d move the ended shows to the bottom of the list in a separate visual block called “Ended shows” or something.
How about three blocks: No label for shows that have definite next airing dates, “Upcoming” for shows that are in progress but don’t have definite air dates and “Ended” for shows that are done.
How about making it an actual option and and a default as you suggest.
I don’t understand what this means.
Make it a option not a default.
