New downloads going to top of que
Mono version (if Sonarr is not running on Windows): 6.10.0
OS: Unraid 6.8.3
When adding new shows they are going to the very top of my downloads list. I have a list of 200+ movies in que currently , when I added a show in sonarr it stopped the movies that were downloading and added this show to the very top of the que. I cannot find any settings within sonarr that cause this.
might be a v3 thing. its in the download client options
That’s caused by your download manager. I use Sabnzb which does the same.
You can set this manually in that program. Kind of like that as then it has full bandwidth for downloading that file instead of sharing it with another download processes.
if you use sab then you can do it in either sonarr or sab
sonarr:
sab:
