Mono version (if Sonarr is not running on Windows): 5.18.0.240-12
OS: Synology DSM 6.2
logs: i don’t have anything to show as i reinstalled sonarr.
hello, i can’t seem to get sonarr to restore from a backup.
i followed the guide to do a restore, but nothing seems to work.
Restore for Synology NAS
CAUTION: Restoring on a Synology requires knowledge of Linux and Root SSH access to the Synology Device.
Re-install Sonarr
Run Sonarr once to get the AppData directory location
Stop Sonarr
Connect to the Synology NAS through SSH and log in as root
Execute the following commands:
rm -r /usr/local/nzbdrone/var/.config/NzbDrone/nzbdrone.db*
cp -f /tmp/nzbdrone_backup/* /usr/local/nzbdrone/var/.config/NzbDrone/
Update permissions on the files:
cd /usr/local/nzbdrone/var/.config/NzbDrone/
chown -R nzbdrone:users *
chmod -R 0644 *
On some installations, the user is different: chown -R sc-nzbdrone:nzbdrone *
Start Sonarr
