I am crashing too… Here is my info as best as I can provide it: http://pastebin.com/EF0T0zz1
Tnx guys for the confirmation. Looks like booting in the -46 kernel is a good workaround until the real problem can be fixed.
TL/DR Debian, 3.10.0 runs stable for a week, starts crashing 1/day after 2 weeks or so. New hardware and Arch Linux. 3.12.1 runs stable for a week. Starts crashing 1/day after 1-2 weeks or so.
As an update. For recollection, my Debian installation seemed to run fine for a week or three. And then at least 10 crashes occurred, randomly (at first every 30-24 hours - in the end they seemed to happen within a few hours). @Taloth knows what I am talking about, he spent about 30 hours on my machines via. SSH.
It seemed there was a very subtle hardware (pentium dualcore laptop 1.5 GHz) error involved affecting memory (1 out of 18 passes showed it in the end).
I swapped the hardware to something much smaller (eeePc 900MHz) that is very reliable, though (tested everything thoroughly and the hardware runs at high load). This time I ran Arch Linux as it offers better control to swap the mono version using the PACkage MANager.
The crashes happened at first. We downgraded at first from 3.12.1 to 3.10.0. Crashes gone. Then we used the recent git 3.12.x branch. Crashes gone. Then we apparently used the stock distro 3.12.1 again (that was crashing) - no crashes. For a day. Then a week. Then two weeks.
A few days ago. Looky looky - SIGSEGV. Sadly I messed around with the system with following things
- Converted FAT/NTFS drives to ext4
- Used mhddfs to pool my drives
- Installed nginx for reverse proxy support
- Implemented quite sophisticated permission restrictions so users (processes) can only write where they need to
- Installed CouchPotato
I waited at first. The SIGSEGVs came 3 times. Again once every 30-24 hours. Now I downgraded mono to 3.10.0 and everything is running like a beast again. That includes 1MB/s NZBget, 2MB/s NFS, Sonarr update, Kodi update for the MariaDB, rsync from 1 usb drive to the other on the same controller and looking for prime numbers while simultaneously error checking. My HTPC will playback (the 2MB/s NFS) at 1080p with no buffering without interruption.
Sonarr has been going strong for 3-4 days again. I wonder if in a week or two the crashes come back even on 3.10.0. Then I would not understand the world anymore and feel taunted, but I guess by now we all do.
Just crashed again on 3.10.0.
Time to check out git, sigh.
I am not sure if this is any help to anyone, but I have been getting the same problems as most on here with Sonarr crashing. I even ditched it for Sickrage it was that bad.
Booting into 3.13.0-46 via grub did seem to help a lot and I would receive a crash maybe once every 24 hours.
Webmin just informed me package updates were available for mono to 4.0.1. I took a risk and upgraded then restarted into the normal kernal and so far everything has been running smoothly for the past 6 hours, and things seem to be quicker. Previously I would get a couple of hours use tops before Sonarr crashed. Hopefully it will remain stable.
I’m getting consistent crashes also, it runs for about 24 hours on each start.
I tried doing the “upstart method” from here
ubuntu server 14.04.2 LTS
kernel 3.13.0-49-generic
mono 3.10.0
sonarr 2.0.0.3004
Is this a consistent problem for others? I’m about to jump ship here. Thanks!
@mrdrew It’s a kernel issue, not technically a sonarr issue. It is being worked. There is the possibility that mono 4.0.1 fixes it.
I just upgraded to mono 4.0.1 on kernel -46. Seems ok. I’m going to give it a little while longer, then move back to a new kernel & see what happens.
I see they have just pushed kernel 51 out the door. Anyone tried it yet?
I already ran the testcase on mono 4.0.1 and kernel 3.13.0-51, fails.
Bug has been filed with the ubuntu kernel bug tracker. At this point there’s little I can do but point ppl at the workarounds.
Would this affect Debian users? I installed Sonarr as a plugin for Open Media Vault and experience the same crashes as others reported in this thread.
I can report daily crashes on FreeBSD 10.1-RELEASE-p6:
- Sonarr: 2.0.0.3004
- Mono: 3.12.1_1
Guys, please read the ‘Data Required’ section at the first post.
I like that idea of updating mono. I followed these instructions to add the official mono repository to my apt-get packages (for ubuntu), then these instructions to force mono to upgrade from 3.xxx to the latest 4.xxx
We’ll see if that works. DolphinPromotions, did that fix it for you? I will check back also.
+20hrs still working…
+30hrs still working. I’m gonna call this wrapped up and fixed!
30 days good to go.
It has improved significantly for me, it has crashed maybe once every 24-36 hours. Previously it was every couple of hours!
Wow. This was driving me insane. I just did a fresh install of Debian Jessie on my VPS, and this and Emby was crashing every couple minutes. It came installed with the 3.16.0-4-amd64 kernel.
Luckily my provider just recently added a full VNC management system, and am able to boot to grub. Running buttery smooth again on 3.2.0-4-amd64 and Mono 4.0.1.
Funnily, because it was happening to both of these, I assumed it was mono. So I never checked here, and found this thread through google. lol
Thanks
Please note I only reported the bug+fix to the ubuntu team. Prolly smart to report it to debian too at one point.
Maybe this thread should be crosslinked at the Emby forum
…and done: http://emby.media/community/index.php?/topic/19955-emby-crashing-ubuntu-server/?p=207271
Yea, that’s probably a good idea! lol
I was so happy to actually get things working again, that I didn’t even think about that. lol Not to mention I was out of town for the weekend while doing this on my phone… Probably not the best practice to alter my server when I only have access to it via phone. lol
Hardware
VM running on i7 XCP server
Linux distribution
Distributor ID: Debian
Description: Debian GNU/Linux 8.0 (jessie)
Release: 8.0
Codename: jessie
Kernel version
Linux xcp-dl 3.16.0-4-amd64 #1 SMP Debian 3.16.7-ckt9-3~deb8u1 (2015-04-24) x86_64 GNU/Linux
Sonarr version
2.0.0.3004
Mono version
4.0.1
I’ve reported this to the kernel people at Debian. After a brief chat on IRC they’re hoping the fixes will go into 3.16.7-ckt11, which might be release tomorrow.
Andy
@adhawkins Re: Debian bugreport.
Please note I’ve never been able to proof that the bug-18026 testcase is the only scenario in which Sonarr crashes. So you’ll definitely have to run Sonarr for a while with 4.0.2 to be sure. 18026 was just a quick way to repro so I could bughunt more efficiently.
Ok.
Do you have any feel for what sonarr actually needs to be doing to trigger it?
I’ve got this set up on a test VM at work, so can’t really have it downloading a load of TV shows there to see if it happens
I could add an indexer and have it searching that if you think it’s likely to trigger the issue?
Andy
