Sonarr version 3.0.6.1196:
Windows 2012:
This isn’t really a bug. Is there anyway to have Sonarr name episodes with “&” and replace it with “And” instead? I know “&” is supported character but windows doesn’t really play well with files that have the “&” character in them. Batch files tend to not work correctly without a decent amount of alteration. “&” also tends to be a protected character in Linux systems so same problem.
Any way to do this?
