Sonarr version (exact version): latest
Mono version (if Sonarr is not running on Windows): NA
OS: Win 10
Debug logs: Na
Description of issue: Mythbusters has renamed all the seasons again on tvdb e.g. from S2012E02 to S11E02 . They did this before a few years ago.
Sonarr is now trying to downloading everything again.
The last time to fix this I just dragged all the old named seasons into the drone factory folder and sonarr imported them all in and renaming them correctly. Any tips on how to fix this without drone factory?
Manual Import.
Thank you Markus
For anyone finding this in a google search you first move all the old SYYYY folders to a temp folder. Then in sonarr click on Wanted and in the Missing tab click the Manual Import button then browse to the temp folder where all your files are.
