Debug log of what? It only shows 1 second of logs, we’d need the full RSS Sync (posted to hastebin). If you go to System: Tasks, when did the RSS Sync last run?
Can you PM me a link (dropbox, google drive, etc) with a copy of your database (you can create a zip using the ((backup)) feature)).
Are there any errors in the logs after going to that page?
yes there are errors after going to that page.
I can dropbox , I don’t really use it but I have an account. I have backed it up, where do i dropbox to?
You’ll need to upload on dropbox and share a link to it.
Thanks. Can you enable ((trace logging)), clear the existing log files, then restart Sonarr, wait a couple minutes then post the contents of of sonarr.trace.txt to hastebin, please?
Also which version of Sonarr (from System: Info)?
Version 2.0.0.3953
what is hastebin?
found hastebin, i posted to it and hit save, how do you get it?
You need to post a link to it here.
The logs didn’t contain a restart of Sonarr, but I found the issue. Your database is corrupt, not completely, but enough that scheduled tasks would never run. I’ll PM you a fixed up version of your database that you will need to ((restore)) (stop Sonarr, remove the old DB as well as the .db-shm
and .db-wal
files, drop in the new one).
Awesome, thank you very much, look forward to doing that
ok, here is hoping it will work, i have a couple for tonight will check when I get home from work
Thanks
well i spoke to soon, one from last night is downloading so it looks like it may have worked. Will keep you posted
Thank you Markus for your help, looks lik eit is all working now
