Multiple Problems after upgrading to V4
Sonarr version (exact version): 4.0.19.2979
Mono version (if Sonarr is not running on Windows): NA
OS: WIN 11
xxx Not needed anymore xxx
After I run v4, Sonarr was upgraded from v2 to v4. I now have several problems:
  1. Downloaded files are not moved to the series folder
  2. If I check download history, I get an error “Unable to load episode history”
  3. If I try to view the series episodes, I get an error “Unable to load episode files”.
I have a backup file of the old database nzbdrone.db if needed… ?
Never mind. I found solution online; Get an SQL editor and then run the command
UPDATE EpisodeFiles SET Languages = ‘[1]’;
on the sonarr.db
Not sure why my db was corrupted after upgrading?
Glad you got it sorted, it’s now importing correctly again?
I am not sure if it will be moving. I moved downloaded shows manually (and that seemed to confuse Sonarr).
The next set of shows airs tomorrow evening; We will see if it moves automatically then.
If not, I will post here for help.
