I recently moved from SB to Sonarr and so far it’s been great bar one issue.
I have noticed multiple folders are being created for the same tv show e.g for “The Magicians” tv show, folder “The Magicians (2015)” was created by SB and all episodes downloaded via Sabnzbd were named “The Magicians.2015.S01E01” etc
Since i have moved to Sonarr, 3 different folders have been created, please see screenshot below.
P.S: I have already deleted the original “The Magicians (2015)” folder.
I assume i have not set something up correctly in media management page.
Please any suggestion on how to fix this issue.
Please see my media management settings below:
FYI - Sabnzbd is handing the tv sorting so i am not sure if it’s a sonarr issue or Sabnzbd
Thanks for the info.
Just spent the last hour looking into this and i think i have sorted it.
Sab is no longer sorting the downloads, instead it’s dumping all files into the download folder and i’m now using “Drone Factory Options” functionality to pick up the shows from the download folder and move to the correct folders.
