In my case - afraid not.
I have been through the series editor and the root folders are correct. There are no series missing from the list after a refresh (that shouldn’t be missing). All episodes are accounted for.
The missing root folders are no longer displaying as root folders - its not causing a problem - just an irritant as it comes up as an error so I go check every time.
Yes I did that exactly.
Only shows the correct path, everything works, is impporting to the new folder. @anon1701 - “The missing root folders are no longer displaying as root folders - its not causing a problem - just an irritant as it comes up as an error so I go check every time.” <-- EXACTLY
