Move Files based on Tags
OS: Docker
Description of issue: Move Series to different Root Folder based on tax
Hey everyone,
Gist: I want, either sonarr or sabnzbd, to move Series and Films (latter via Radarr) based on Tags.
Use Case: My Setup allows my Family to download stuff by simply adding stuff to their plex watchlist and has a few automated stuff that adds trending series. I however don’t want to clog my cloud backup solution with a buttload of series which just lay there. We all know how people are: They just Request stuff and then it sits there and now I want to change my setup.
Setup:
Folder: A /Series folder and a /SeriesReq folder.
Tagging: Stuff that’s coming from the Plex Watchlists is already tagged with a unique Tag
Problem: I fail to find the correct settings in Sonarr to actually Move all tagged Files to /Series (the ones without tags) and to /SeriesReq (the ones with the Tag). Currently only the RSS-Feed stuff works because its in the RSS settings.
Goal: Populate the /SeriesReq Folder with the stuff that others request or me tag with this unique tag. In my Backup solution I then only want to Backup the /Series Folder but exclude /SeriesReq
If someone could nudge me to the right direction this would be highly appreciated because I genuinely can’t find it, and from my understanding of the different Root-Folders this should be possible.
Thank you for your help!
Sonarr can’t currently set the series path based on different tags, there is a request for it though. If you’re able to determine where it should go at the time of import you could set the root folder when adding the series (or in the case of import list, set the root folder for that import list).
