I think this may be a bug, but my sonarr reports conflicting things.
Manual search shows "Quality for existing file on disk is of equal or higher preference: HDTV-720p v1"
Episode list shows “Episode Missing from disk”.
Nzbget is empty.
Anything other than manually selecting the episode basically is broken. I think this happened because I deleted the download from NZBget, is there anyway to tell sonarr to update itself?/forget about the old file?.
I tried deleting and re-importing the series, but sonarr still thinks it has a file that is of better quality and doesn’t exist
