OK, been using Drone for a while now, but have noticed a recurring problem. If a whole season gets posted in a higher quality than what I already have, it always seems to only catch the tail end of the releases. For example, I saw this in my log from earlier today:
14-10-6 10:40:03.0|Info|RssSyncService|Starting RSS Sync
14-10-6 10:40:08.8|Info|DownloadDecisionMaker|Processing 197 reports
14-10-6 10:40:18.0|Info|RssSyncService|RSS Sync Completed. Reports found: 197, Reports grabbed: 0
14-10-6 10:50:37.9|Info|RssSyncService|Starting RSS Sync
14-10-6 10:50:48.7|Info|DownloadDecisionMaker|Processing 197 reports
14-10-6 10:50:58.1|Info|RssSyncService|RSS Sync Completed. Reports found: 197, Reports grabbed: 0
14-10-6 11:01:18.7|Info|RssSyncService|Starting RSS Sync
14-10-6 11:01:28.5|Info|DownloadDecisionMaker|Processing 197 reports
14-10-6 11:01:40.4|Info|Sabnzbd|Adding report [Supernatural S09E18.1080p BluRay x264-ROVERS] to the queue.
14-10-6 11:01:42.0|Info|DownloadService|Report sent to download client. Supernatural S09E18.1080p BluRay x264-ROVERS
14-10-6 11:01:46.4|Info|Sabnzbd|Adding report [Supernatural S09E19.1080p BluRay x264-ROVERS] to the queue.
14-10-6 11:01:48.4|Info|DownloadService|Report sent to download client. Supernatural S09E19.1080p BluRay x264-ROVERS
14-10-6 11:01:51.3|Info|RssSyncService|RSS Sync Completed. Reports found: 197, Reports grabbed: 2
After episodes 18 & 19 it went on and found the remainder of the season, but nothing from before episode 18 even though they were all uploaded at that time. An automatic search of the season later on this evening picked up all the episodes but many failed at that point, assumably due to takedown requests.
So my question is why did Drone miss episodes 1 -17? I can see it running the RSS check every 10 minutes all morning without ever noticing that anything was posted until episode 18 onwards. All episodes in the season were flagged for monitoring, and this isn’t the first time I’ve seen it happen. It also seems strange that the RSS returns 197 results every single time it runs - I thought it would find as many items as were posted in the last 10 minutes, which would be a different number each time?
If you’d like a fuller log or anything like that please just let me know what to do, first time I’ve posted on here. Thanks
