Sonarr version (exact version): 2.0.0.5054
OS: Windows Server 2008 R2
I’m getting this Format Exception for a particular completed file when it’s being imported. Seems to be a problem with what media info is returning for audio channels isn’t correctly parsed into a decimal.
[v2.0.0.5054] System.FormatException: Input string was not in a correct format.
at System.Number.StringToNumber(String str, NumberStyles options, NumberBuffer& number, NumberFormatInfo info, Boolean parseDecimal)
at System.Number.ParseDecimal(String value, NumberStyles options, NumberFormatInfo numfmt)
at NzbDrone.Core.MediaFiles.MediaInfo.MediaInfoFormatter.<>c.<FormatAudioChannels>b__1_1(String s) in M:\BuildAgent\work\b69c1fe19bfc2c38\src\NzbDrone.Core\MediaFiles\MediaInfo\MediaInfoFormatter.cs:line 48
at System.Linq.Enumerable.WhereSelectArrayIterator`2.MoveNext()
at System.Linq.Enumerable.Sum(IEnumerable`1 source)
at NzbDrone.Core.MediaFiles.MediaInfo.MediaInfoFormatter.FormatAudioChannels(MediaInfoModel mediaInfo) in M:\BuildAgent\work\b69c1fe19bfc2c38\src\NzbDrone.Core\MediaFiles\MediaInfo\MediaInfoFormatter.cs:line 44
at NzbDrone.Core.Organizer.FileNameBuilder.AddMediaInfoTokens(Dictionary`2 tokenHandlers, EpisodeFile episodeFile) in M:\BuildAgent\work\b69c1fe19bfc2c38\src\NzbDrone.Core\Organizer\FileNameBuilder.cs:line 496
at NzbDrone.Core.Organizer.FileNameBuilder.BuildFileName(List`1 episodes, Series series, EpisodeFile episodeFile, NamingConfig namingConfig) in M:\BuildAgent\work\b69c1fe19bfc2c38\src\NzbDrone.Core\Organizer\FileNameBuilder.cs:line 133
at NzbDrone.Core.MediaFiles.EpisodeFileMovingService.MoveEpisodeFile(EpisodeFile episodeFile, LocalEpisode localEpisode) in M:\BuildAgent\work\b69c1fe19bfc2c38\src\NzbDrone.Core\MediaFiles\EpisodeFileMovingService.cs:line 74
at NzbDrone.Core.MediaFiles.UpgradeMediaFileService.UpgradeEpisodeFile(EpisodeFile episodeFile, LocalEpisode localEpisode, Boolean copyOnly) in M:\BuildAgent\work\b69c1fe19bfc2c38\src\NzbDrone.Core\MediaFiles\UpgradeMediaFileService.cs:line 76
at NzbDrone.Core.MediaFiles.EpisodeImport.ImportApprovedEpisodes.Import(List`1 decisions, Boolean newDownload, DownloadClientItem downloadClientItem, ImportMode importMode) in M:\BuildAgent\work\b69c1fe19bfc2c38\src\NzbDrone.Core\MediaFiles\EpisodeImport\ImportApprovedEpisodes.cs:line 103
This is what the media info cli is returning for the audio info:
Audio
Format : E-AC-3
Format/Info : Enhanced Audio Coding 3
Format profile : E-AC-3+Atmos / E-AC-3
Format settings, Endianness : Big
Codec ID : A_EAC3
Duration : 51 min 16 s
Bit rate mode : Constant
Bit rate : 448 kb/s
Channel(s) : 15 objects / 6 channels
Channel positions : 15 objects / Front: L C R, Side: L R, LFE
Sampling rate : 48.0 kHz
Frame rate : 187.500 FPS (256 SPF)
Compression mode : Lossy
Stream size : 164 MiB (5%)
Language : German
Service kind : Complete Main
Default : Yes
Forced : No
