Media checker and tester
I think a lot of the people here have large media libraries. So many files it is near impossible to manually check to see if they all work. Its frustrating to try to watch something you had on your server for years only to find out it is somehow not working, in the wrong language or not the show you thought it was.
Can we add a feature to Sonarr and Radarr where:
It goes through each movie or tv show, sees if it will play fully. ( not corrupt)
Check to see if it is the right movie or show, you might have it mislabeled, so get meta data, was the show you intended it to be 120 minutes, but the file you actually have is only 90 minutes? notify it does not add up.
Notify or auto correct if a show is missing or corrupt?
I know VLC can detect and fix corrupt files, so I imagine it is not too hard to do that…well not too hard for someone else to do, I certainly cant do it :slight_smile:
It would be amazing to know every file in my server actually worked and was not corrupted.
