I’ve been adding a bunch of new shows recently, and yesterday I noticed the alphabetically last shows were getting cut off on the “series” list. Then I noticed the stats at the bottom of the list says 1000 series, so I checked my “TV Shows” folder, which has 1026 shows.
I can get the shows that are getting cut off the series list to appear by toggling the “continuing” and “ended” button, but when I try to go to the show pages for shows cut off from the main list, I get a “OMG 404 Not Found” graphic.
I just chose a number when I was setting up grabbing the series from the API for the UI, turns out it was 1000, increased it to 100000 in the latest develop build 2.0.0.1237. I believe it should fix the 404 as well, but please let me know.
