My main PC hard drive died so I had an older backup of my sonarr files.
I did a fresh install of Sonarr then copied over my files. This worked except…
If I go into Activity, the Que, I have over 756 entries. Is there ANY was to mass delete these?
I have gone into the series(ex Arrow) and unchecked the watch icons for both the series as well as single episodes.
Any help will be greatly appreciated.
Sonarr version (2.0.0.5163):
Windows 10:
Which download client(s)?
Mass delete from Activity: Queue will remove them from your download client. If they are seeding torrents you still wish to seed you won’t want that.
If you don’t need to keep seeding them or they’re not torrents you have a few options:
- Remove them from the download client directly (Sonarr’s queue is built on what the download client has in it)
- Change the label/category for them in the download client
- Have Sonarr use a different category
I’m sorry, I should have mentioned that these are NZB’s and they were in SABNZB but I removed them.
system
Closed
4
