Sonarr version: Sonarr Ver. 2.0.0.5338 Mono version: Mono JIT compiler version 5.20.1.34 (tarball Tue Jul 16 22:52:32 UTC 2019) OS: NAME=“Ubuntu” VERSION=“18.04.3 LTS (Bionic Beaver)” Debug logs: https://pastebin.com/fZwZneDk Description of issue: I keep getting all these errors in sonarr, and it’s making it very slow, and it also seems that it’s continuously doing RSS sync. Any idea what could be causing this?
I restarted the machine and the problem was fixed. The DB is located on a remote NFS share, if that makes a difference. Anyway, problem solved for now.
You’d really want the DB on a local disk rather than on a NFS share. If the NFS share slows down or has problems, you are going to see exactly what those logs were showing.
