Sonarr version (exact version): 4.0.19.2979
Mono version (if Sonarr is not running on Windows): N/A (Running on .NET 6.0.13)
OS: ZimaOS Docker (linuxserver.io container 4.0.19.2979-ls322)
Debug logs: N/A - Internal metadata title slug collision on the Skyhook proxy backend. No local application error log is generated.
I am attempting to add both separate listings for the anime series “Vampire Princess Miyu” (the 1988 OVA and the 1997 TV Series). Both entries populate independently in Plex and in Sonarr with their correct years in the search dropdown box. However, when trying to save the second series, the action is blocked on the backend due to an identical alphanumeric title slug (vampire-princess-miyu) generated by Skyhook.
Could a manual Skyhook slug override please be implemented to differentiate these two specific TVDB IDs so they can be tracked simultaneously?
- Series 1: Vampire Princess Miyu (1988) - TVDB ID: 480793
- Series 2: Vampire Princess Miyu (1997) - TVDB ID: 70862
Thank you!
