has anyone an idea why sonarr would suggest S02E10 for a file that is clearly numbered S02E07? (even the name in the file matches the correct episode name)
okay makes sense now… but I downloaded them in tvdb order… There is no way to override it for the import is there? Except to manually click every entry and correct the episode or renaming all the files right?
Moving them into the series folder manually would probably be the easiest then.
move the files into the correct series/season folders
click the “update series info and scan disk” button, either from the series list or individual series detail page in sonarr
sonarr should now be aware of the files
if required: from the series detail page, click the “preview rename for all episodes” button to rename the files (by rename I mean follow the naming scheme from settings > media management, not change the episode numbering)
