OS: Linux (Docker on Synology)
Debug logs: below
Description of issue: Seems very similar to: Manual import stopped working, how do
I tried a few different variants of naming the file with a quality type, but the only thing that finally worked was removing the name of the episode as well.
So, this file name didn’t work: ‘The Simpsons.S25E21.Pay Pal.1080p.mkv’, nor did: ‘The Simpsons.S25E21.Pay Pal.mkv’, but this did: ‘The Simpsons.S25E21.mkv’. I also discovered (randomly) that a completely different episode name in the file worked, but anything with the actual name of the episode did not (so this worked: ‘The Simpsons.S25E21.1080p.test.mkv’)
I had other episodes with exactly the same name formats and they all imported correctly, it was just this one that failed. Seems like a bug with the parser?
20-1-3 11:59:16.7|Trace|Http|Req: 1156 [GET] /api/manualimport?folder=%2Fmnt%2Fnas%2FVideos%2F.deluge%2FThe+Simpsons%2F&sort_by=qualityWeight&order=desc
20-1-3 11:59:16.7|Debug|Parser|Parsing string 'The Simpsons'
20-1-3 11:59:16.8|Debug|Parser|Unable to parse The Simpsons
20-1-3 11:59:16.8|Debug|Parser|Parsing string 'The Simpsons'
20-1-3 11:59:16.8|Debug|DiskScanService|Scanning '/mnt/nas/Videos/.deluge/The Simpsons/' for video files
20-1-3 11:59:16.8|Trace|DiskScanService|1 files were found in /mnt/nas/Videos/.deluge/The Simpsons/
20-1-3 11:59:16.8|Debug|DiskScanService|1 video files were found in /mnt/nas/Videos/.deluge/The Simpsons/
20-1-3 11:59:17.1|Debug|ImportDecisionMaker|Analyzing 1/1 files.
20-1-3 11:59:17.1|Debug|VideoFileInfoReader|Getting media info from /mnt/nas/Videos/.deluge/The Simpsons/Season 25/The Simpsons.S25E21.Pay Pal.mkv
20-1-3 11:59:17.2|Trace|MediaInfo|Read file offset 0-32768 (32768 bytes)
20-1-3 11:59:17.2|Trace|MediaInfo|Read file offset 418510356-418517400 (7044 bytes)
20-1-3 11:59:17.2|Trace|MediaInfo|Read a total of 39812 bytes (0.0%)
20-1-3 11:59:17.2|Debug|DetectSample|Runtime is over 90 seconds
20-1-3 11:59:17.2|Debug|Parser|Parsing string 'The Simpsons.S25E21.Pay Pal.mkv'
20-1-3 11:59:17.2|Trace|Parser|^(?<title>.+?)(?:(?:[-_\W](?<![()\[!]))+S?(?<season>(?<!\d+)(?:\d{1,2})(?!\d+))(?:[ex]|\W[ex]){1,2}(?<episode>\d{2,3}(?!\d+))(?:(?:\-|[ex]|\W[ex]|_){1,2}(?<episode>\d{2,3}(?!\d+)))*)\W?(?!\\)
20-1-3 11:59:17.2|Debug|Parser|Episode Parsed. The Simpsons - S25E21
20-1-3 11:59:17.2|Debug|Parser|Language parsed: English
20-1-3 11:59:17.2|Debug|QualityParser|Trying to parse quality for The Simpsons.S25E21.Pay Pal.mkv
20-1-3 11:59:17.2|Debug|Parser|Quality parsed: DVD v1
20-1-3 11:59:17.2|Debug|Parser|Release Group parsed:
20-1-3 11:59:17.2|Debug|VideoFileInfoReader|Getting media info from /mnt/nas/Videos/.deluge/The Simpsons/Season 25/The Simpsons.S25E21.Pay Pal.mkv
20-1-3 11:59:17.2|Debug|AggregateQuality|Using quality: v1
20-1-3 11:59:17.2|Debug|EpisodeTitleSpecification|Episode aired more than 1 day ago
20-1-3 11:59:17.2|Debug|FreeSpaceSpecification|Skipping free space check when importing
20-1-3 11:59:17.2|Debug|SameFileSpecification|No existing episode file, skipping
20-1-3 11:59:17.2|Debug|MatchesFolderSpecification|No folder ParsedEpisodeInfo, skipping check
20-1-3 11:59:17.2|Trace|ConfigService|Using default config value for 'downloadclientworkingfolders' defaultValue:'_UNPACK_|_FAILED_'
20-1-3 11:59:17.2|Debug|ImportDecisionMaker|File accepted
20-1-3 11:59:17.2|Trace|NzbDroneErrorPipeline|Handling Exception
20-1-3 11:59:17.2|Fatal|NzbDroneErrorPipeline|Request Failed. GET /api/manualimport
[v2.0.0.5338] System.InvalidOperationException: Sequence contains no matching element
at System.Linq.Enumerable.Single[TSource] (System.Collections.Generic.IEnumerable`1[T] source, System.Func`2[T,TResult] predicate) [0x00070] in <798dd06330af4ca3886d7d2be5573af7>:0
at NzbDrone.Api.ManualImport.ManualImportModule.AddQualityWeight (NzbDrone.Api.ManualImport.ManualImportResource item) [0x00020] in M:\BuildAgent\work\5d7581516c0ee5b3\src\NzbDrone.Api\ManualImport\ManualImportModule.cs:35
at System.Linq.Enumerable+SelectListIterator`2[TSource,TResult].ToList () [0x0002a] in <798dd06330af4ca3886d7d2be5573af7>:0
at System.Linq.Enumerable.ToList[TSource] (System.Collections.Generic.IEnumerable`1[T] source) [0x0001f] in <798dd06330af4ca3886d7d2be5573af7>:0
at NzbDrone.Api.ManualImport.ManualImportModule.GetMediaFiles () [0x001c4] in M:\BuildAgent\work\5d7581516c0ee5b3\src\NzbDrone.Api\ManualImport\ManualImportModule.cs:28
at NzbDrone.Api.REST.RestModule`1[TResource].<set_GetResourceAll>b__32_0 (System.Object options) [0x00000] in M:\BuildAgent\work\5d7581516c0ee5b3\src\NzbDrone.Api\REST\RestModule.cs:111
at (wrapper dynamic-method) System.Object.CallSite.Target(System.Runtime.CompilerServices.Closure,System.Runtime.CompilerServices.CallSite,System.Func`2<object, object>,object)
at Nancy.Routing.Route+<>c__DisplayClass4.<Wrap>b__3 (System.Object parameters, System.Threading.CancellationToken context) [0x00049] in <63c44d6f8d7e4f339a987bf9eb94d931>:0
20-1-3 11:59:17.2|Trace|Http|Res: 1156 [GET] /api/manualimport?folder=%2Fmnt%2Fnas%2FVideos%2F.deluge%2FThe+Simpsons%2F&sort_by=qualityWeight&order=desc: 500.InternalServerError (526 ms)
20-1-3 11:59:17.2|Debug|Api|[GET] /api/manualimport?folder=%2Fmnt%2Fnas%2FVideos%2F.deluge%2FThe+Simpsons%2F&sort_by=qualityWeight&order=desc: 500.InternalServerError (526 ms)
20-1-3 11:59:20.4|Trace|Http|Req: 1157 [GET] /api/config/mediamanagement
20-1-3 11:59:20.4|Trace|ConfigService|Using default config value for 'recyclebin' defaultValue:''
20-1-3 11:59:20.4|Trace|ConfigService|Using default config value for 'autodownloadpropers' defaultValue:'True'
20-1-3 11:59:20.4|Trace|ConfigService|Using default config value for 'createemptyseriesfolders' defaultValue:'False'
20-1-3 11:59:20.4|Trace|Http|Req: 1158 [GET] /api/config/naming
20-1-3 11:59:20.4|Trace|ConfigService|Using default config value for 'filedate' defaultValue:'None'
20-1-3 11:59:20.5|Trace|Http|Req: 1159 [GET] /api/config/indexer
20-1-3 11:59:20.5|Trace|Http|Req: 1160 [GET] /api/config/downloadclient
20-1-3 11:59:20.5|Trace|Http|Req: 1161 [GET] /api/notification
20-1-3 11:59:20.5|Trace|ConfigService|Using default config value for 'downloadedepisodesfolder' defaultValue:''
20-1-3 11:59:20.5|Trace|ConfigService|Using default config value for 'minimumage' defaultValue:'0'
20-1-3 11:59:20.5|Trace|ConfigService|Using default config value for 'filechmod' defaultValue:'0644'
20-1-3 11:59:20.5|Trace|ConfigService|Using default config value for 'maximumsize' defaultValue:'0'
20-1-3 11:59:20.5|Trace|ConfigService|Using default config value for 'downloadclientworkingfolders' defaultValue:'_UNPACK_|_FAILED_'
20-1-3 11:59:20.5|Trace|ConfigService|Using default config value for 'copyusinghardlinks' defaultValue:'True'
20-1-3 11:59:20.5|Trace|ConfigService|Using default config value for 'importextrafiles' defaultValue:'False'
20-1-3 11:59:20.5|Trace|ConfigService|Using default config value for 'downloadedepisodesscaninterval' defaultValue:'1'
20-1-3 11:59:20.5|Trace|ConfigService|Using default config value for 'autoredownloadfailed' defaultValue:'True'
20-1-3 11:59:20.5|Trace|ConfigService|Using default config value for 'retention' defaultValue:'0'
20-1-3 11:59:20.5|Trace|Http|Res: 1158 [GET] /api/config/naming: 200.OK (30 ms)
20-1-3 11:59:20.5|Trace|ConfigService|Using default config value for 'removefaileddownloads' defaultValue:'True'
20-1-3 11:59:20.5|Trace|Http|Res: 1161 [GET] /api/notification: 200.OK (13 ms)
20-1-3 11:59:20.5|Trace|ConfigService|Using default config value for 'rsssyncinterval' defaultValue:'15'
20-1-3 11:59:20.5|Debug|Api|[GET] /api/config/naming: 200.OK (30 ms)
20-1-3 11:59:20.5|Trace|Http|Res: 1160 [GET] /api/config/downloadclient: 200.OK (24 ms)
20-1-3 11:59:20.5|Debug|Api|[GET] /api/notification: 200.OK (13 ms)
20-1-3 11:59:20.5|Trace|ConfigService|Using default config value for 'extrafileextensions' defaultValue:'srt'
20-1-3 11:59:20.5|Trace|Http|Res: 1159 [GET] /api/config/indexer: 200.OK (28 ms)
20-1-3 11:59:20.5|Debug|Api|[GET] /api/config/downloadclient: 200.OK (24 ms)
20-1-3 11:59:20.5|Trace|ConfigService|Using default config value for 'enablemediainfo' defaultValue:'True'
20-1-3 11:59:20.5|Debug|Api|[GET] /api/config/indexer: 200.OK (28 ms)
20-1-3 11:59:20.5|Trace|Http|Res: 1157 [GET] /api/config/mediamanagement: 200.OK (72 ms)
20-1-3 11:59:20.5|Trace|Http|Req: 1162 [GET] /api/config/host
20-1-3 11:59:20.5|Trace|Http|Req: 1163 [GET] /api/config/ui
20-1-3 11:59:20.5|Trace|ConfigService|Using default config value for 'firstdayofweek' defaultValue:'0'
20-1-3 11:59:20.5|Trace|ConfigService|Using default config value for 'calendarweekcolumnheader' defaultValue:'ddd M/D'
20-1-3 11:59:20.5|Trace|ConfigService|Using default config value for 'shortdateformat' defaultValue:'MMM D YYYY'
20-1-3 11:59:20.5|Trace|ConfigService|Using default config value for 'longdateformat' defaultValue:'dddd, MMMM D YYYY'
20-1-3 11:59:20.5|Trace|ConfigService|Using default config value for 'timeformat' defaultValue:'h(:mm)a'
20-1-3 11:59:20.5|Debug|Api|[GET] /api/config/mediamanagement: 200.OK (72 ms)
20-1-3 11:59:20.5|Trace|ConfigService|Using default config value for 'showrelativedates' defaultValue:'True'
20-1-3 11:59:20.5|Trace|ConfigService|Using default config value for 'enablecolorimpairedmode' defaultValue:'False'
20-1-3 11:59:20.5|Trace|Http|Res: 1163 [GET] /api/config/ui: 200.OK (27 ms)
20-1-3 11:59:20.5|Trace|ConfigService|Using default config value for 'proxyenabled' defaultValue:'False'
20-1-3 11:59:20.5|Debug|Api|[GET] /api/config/ui: 200.OK (27 ms)
20-1-3 11:59:20.5|Trace|ConfigService|Using default config value for 'proxytype' defaultValue:'Http'
20-1-3 11:59:20.6|Trace|ConfigService|Using default config value for 'proxyhostname' defaultValue:''
20-1-3 11:59:20.6|Trace|ConfigService|Using default config value for 'proxyport' defaultValue:'8080'
20-1-3 11:59:20.6|Trace|ConfigService|Using default config value for 'proxyusername' defaultValue:''
20-1-3 11:59:20.6|Trace|ConfigService|Using default config value for 'proxypassword' defaultValue:''
20-1-3 11:59:20.6|Trace|ConfigService|Using default config value for 'proxybypassfilter' defaultValue:''
20-1-3 11:59:20.6|Trace|ConfigService|Using default config value for 'proxybypasslocaladdresses' defaultValue:'True'
20-1-3 11:59:20.6|Trace|Http|Res: 1162 [GET] /api/config/host: 200.OK (67 ms)
20-1-3 11:59:20.6|Debug|Api|[GET] /api/config/host: 200.OK (67 ms)
20-1-3 11:59:20.6|Trace|Http|Req: 1164 [GET] /api/config/naming/samples?renameEpisodes=false&replaceIllegalCharacters=true&multiEpisodeStyle=0&standardEpisodeFormat=%7BSeries+Title%7D+-+S%7Bseason%3A00%7DE%7Bepisode%3A00%7D+-+%7BEpisode+Title%7D+%7BQuality+Full%7D&dailyEpisodeFormat=%7BSeries+Title%7D+-+%7BAir-Date%7D+-+%7BEpisode+Title%7D+%7BQuality+Full%7D&animeEpisodeFormat=%7BSeries+Title%7D+-+S%7Bseason%3A00%7DE%7Bepisode%3A00%7D+-+%7BEpisode+Title%7D+%7BQuality+Full%7D&seriesFolderFormat=%7BSeries+Title%7D&seasonFolderFormat=Season+%7Bseason%3A00%7D&includeSeriesTitle=false&includeEpisodeTitle=false&includeQuality=false&replaceSpaces=true&separator=+-+&numberStyle=S%7Bseason%3A00%7DE%7Bepisode%3A00%7D&id=1
20-1-3 11:59:20.6|Trace|Http|Req: 1165 [GET] /api/profile
20-1-3 11:59:20.6|Debug|Parser|Parsing string 'Series.Title.S01E01.720p.HDTV.x264-EVOLVE'
20-1-3 11:59:20.6|Trace|Parser|^(?<title>.+?)(?:(?:[-_\W](?<![()\[!]))+S?(?<season>(?<!\d+)(?:\d{1,2})(?!\d+))(?:[ex]|\W[ex]){1,2}(?<episode>\d{2,3}(?!\d+))(?:(?:\-|[ex]|\W[ex]|_){1,2}(?<episode>\d{2,3}(?!\d+)))*)\W?(?!\\)
20-1-3 11:59:20.6|Debug|Parser|Episode Parsed. Series Title - S01E01
20-1-3 11:59:20.6|Trace|Http|Req: 1166 [GET] /api/delayprofile
20-1-3 11:59:20.6|Debug|Parser|Language parsed: English
20-1-3 11:59:20.6|Debug|QualityParser|Trying to parse quality for Series.Title.S01E01.720p.HDTV.x264-EVOLVE
20-1-3 11:59:20.6|Debug|Parser|Quality parsed: HDTV-720p v1
20-1-3 11:59:20.6|Debug|Parser|Release Group parsed: EVOLVE
20-1-3 11:59:20.6|Trace|Http|Req: 1167 [GET] /api/qualitydefinition
20-1-3 11:59:20.6|Trace|Http|Req: 1168 [GET] /api/indexer
20-1-3 11:59:20.6|Trace|Http|Res: 1167 [GET] /api/qualitydefinition: 200.OK (10 ms)
20-1-3 11:59:20.6|Debug|Parser|Parsing string 'Series.Title.S01E01-E03.720p.HDTV.x264-EVOLVE'
20-1-3 11:59:20.6|Debug|Api|[GET] /api/qualitydefinition: 200.OK (10 ms)
20-1-3 11:59:20.6|Trace|Http|Res: 1166 [GET] /api/delayprofile: 200.OK (21 ms)
20-1-3 11:59:20.6|Trace|Http|Res: 1165 [GET] /api/profile: 200.OK (24 ms)
20-1-3 11:59:20.6|Debug|Api|[GET] /api/profile: 200.OK (24 ms)
20-1-3 11:59:20.6|Debug|Api|[GET] /api/delayprofile: 200.OK (21 ms)
20-1-3 11:59:20.6|Debug|Parser|Episode Parsed. Series Title - S01E01-02-03
20-1-3 11:59:20.7|Debug|QualityParser|Trying to parse quality for Series.Title.S01E01-E03.720p.HDTV.x264-EVOLVE
20-1-3 11:59:20.7|Debug|Parser|Quality parsed: HDTV-720p v1
20-1-3 11:59:20.7|Debug|Parser|Release Group parsed: EVOLVE
20-1-3 11:59:20.7|Trace|Http|Req: 1169 [GET] /api/Restriction
20-1-3 11:59:20.7|Trace|Http|Res: 1169 [GET] /api/Restriction: 200.OK (4 ms)
20-1-3 11:59:20.7|Debug|Parser|Parsing string 'Series.Title.2013.10.30.HDTV.x264-EVOLVE'
20-1-3 11:59:20.7|Debug|Api|[GET] /api/Restriction: 200.OK (4 ms)
20-1-3 11:59:20.7|Trace|Parser|^(?<title>.+?)?\W*(?<airyear>\d{4})[-_. ]+(?<airmonth>[0-1][0-9])[-_. ]+(?<airday>[0-3][0-9])(?![-_. ]+[0-3][0-9])
20-1-3 11:59:20.7|Debug|Parser|Episode Parsed. Series Title - 2013-10-30
20-1-3 11:59:20.7|Debug|Parser|Language parsed: English
20-1-3 11:59:20.7|Debug|QualityParser|Trying to parse quality for Series.Title.2013.10.30.HDTV.x264-EVOLVE
20-1-3 11:59:20.7|Debug|Parser|Quality parsed: SDTV v1
20-1-3 11:59:20.7|Debug|Parser|Parsing string '[RlsGroup] Series Title - 001 [720p]'
20-1-3 11:59:20.7|Trace|Http|Res: 1168 [GET] /api/indexer: 200.OK (67 ms)
20-1-3 11:59:20.7|Trace|Parser|^\[(?<subgroup>.+?)\][-_. ]?(?<title>.+?)(?:[. ]-[. ](?<absoluteepisode>\d{2,3}(\.\d{1,2})?(?!\d+|[-])))+(?:[-_. ]+(?<special>special|ova|ovd))?.*?(?<hash>\[\w{8}\])?(?:$|\.mkv)
20-1-3 11:59:20.7|Trace|Http|Req: 1170 [GET] /api/downloadclient
20-1-3 11:59:20.7|Trace|Http|Req: 1171 [GET] /api/remotePathMapping
20-1-3 11:59:20.7|Debug|Api|[GET] /api/indexer: 200.OK (67 ms)
20-1-3 11:59:20.7|Trace|Http|Res: 1171 [GET] /api/remotePathMapping: 200.OK (21 ms)
20-1-3 11:59:20.7|Debug|Parser|Episode Parsed. Series Title - 001
20-1-3 11:59:20.7|Debug|Api|[GET] /api/remotePathMapping: 200.OK (21 ms)
20-1-3 11:59:20.7|Debug|QualityParser|Trying to parse quality for [RlsGroup] Series Title - 001 [720p]
20-1-3 11:59:20.7|Debug|Parser|Release Group parsed: RlsGroup
20-1-3 11:59:20.7|Debug|Parser|Parsing string '[RlsGroup] Series Title - 001 - 103 [720p]'
20-1-3 11:59:20.7|Trace|Http|Req: 1172 [GET] /api/metadata
20-1-3 11:59:20.8|Debug|Parser|Episode Parsed. Series Title - 001-002-003-004-005-006-007-008-009-010-011-012-013-014-015-016-017-018-019-020-021-022-023-024-025-026-027-028-029-030-031-032-033-034-035-036-037-038-039-040-041-042-043-044-045-046-047-048-049-050-051-052-053-054-055-056-057-058-059-060-061-062-063-064-065-066-067-068-069-070-071-072-073-074-075-076-077-078-079-080-081-082-083-084-085-086-087-088-089-090-091-092-093-094-095-096-097-098-099-100-101-102-103
20-1-3 11:59:20.8|Trace|Http|Res: 1170 [GET] /api/downloadclient: 200.OK (56 ms)
20-1-3 11:59:20.8|Debug|Api|[GET] /api/downloadclient: 200.OK (56 ms)
20-1-3 11:59:20.8|Debug|Parser|Language parsed: English
20-1-3 11:59:20.8|Debug|QualityParser|Trying to parse quality for [RlsGroup] Series Title - 001 - 103 [720p]
20-1-3 11:59:20.8|Debug|Parser|Quality parsed: HDTV-720p v1
20-1-3 11:59:20.8|Debug|Parser|Release Group parsed: RlsGroup
20-1-3 11:59:20.8|Trace|Http|Res: 1164 [GET] /api/config/naming/samples?renameEpisodes=false&replaceIllegalCharacters=true&multiEpisodeStyle=0&standardEpisodeFormat=%7BSeries+Title%7D+-+S%7Bseason%3A00%7DE%7Bepisode%3A00%7D+-+%7BEpisode+Title%7D+%7BQuality+Full%7D&dailyEpisodeFormat=%7BSeries+Title%7D+-+%7BAir-Date%7D+-+%7BEpisode+Title%7D+%7BQuality+Full%7D&animeEpisodeFormat=%7BSeries+Title%7D+-+S%7Bseason%3A00%7DE%7Bepisode%3A00%7D+-+%7BEpisode+Title%7D+%7BQuality+Full%7D&seriesFolderFormat=%7BSeries+Title%7D&seasonFolderFormat=Season+%7Bseason%3A00%7D&includeSeriesTitle=false&includeEpisodeTitle=false&includeQuality=false&replaceSpaces=true&separator=+-+&numberStyle=S%7Bseason%3A00%7DE%7Bepisode%3A00%7D&id=1: 200.OK (174 ms)
20-1-3 11:59:20.8|Debug|Api|[GET] /api/config/naming/samples?renameEpisodes=false&replaceIllegalCharacters=true&multiEpisodeStyle=0&standardEpisodeFormat=%7BSeries+Title%7D+-+S%7Bseason%3A00%7DE%7Bepisode%3A00%7D+-+%7BEpisode+Title%7D+%7BQuality+Full%7D&dailyEpisodeFormat=%7BSeries+Title%7D+-+%7BAir-Date%7D+-+%7BEpisode+Title%7D+%7BQuality+Full%7D&animeEpisodeFormat=%7BSeries+Title%7D+-+S%7Bseason%3A00%7DE%7Bepisode%3A00%7D+-+%7BEpisode+Title%7D+%7BQuality+Full%7D&seriesFolderFormat=%7BSeries+Title%7D&seasonFolderFormat=Season+%7Bseason%3A00%7D&includeSeriesTitle=false&includeEpisodeTitle=false&includeQuality=false&replaceSpaces=true&separator=+-+&numberStyle=S%7Bseason%3A00%7DE%7Bepisode%3A00%7D&id=1: 200.OK (174 ms)
20-1-3 11:59:20.8|Trace|Http|Res: 1172 [GET] /api/metadata: 200.OK (63 ms)
20-1-3 11:59:20.8|Debug|Api|[GET] /api/metadata: 200.OK (63 ms)
20-1-3 11:59:26.1|Trace|Http|Req: 1173 [PUT] /api/config/host
20-1-3 11:59:26.2|Trace|EventAggregator|Publishing ConfigFileSavedEvent
20-1-3 11:59:26.2|Trace|HttpClient|Req: [GET] http://services.sonarr.tv/v1/update/master?version=2.0.0.5338&os=linux&runtimeVer=5.20.1.34
20-1-3 11:59:26.2|Trace|ConfigService|Using default config value for 'proxyenabled' defaultValue:'False'
20-1-3 11:59:26.2|Trace|EventAggregator|ConfigFileSavedEvent ~> ReconfigureLogging
20-1-3 11:59:26.2|Trace|ConfigService|Using default config value for 'downloadedepisodesfolder' defaultValue:''
